painting carbs ok?
Wondering is painting my Zeniths would be a good or bad idea. Would look nice, but any issues with this other than making sure I'm using the gas resistant paint?
I like them I drive them
Old 10-17-2010, 10:21 AM
ratpiper71T's Avatar
I vote bad. Not only for asthetics, which is my own pinion and probaly of little value, but this brings back memories of me painting my calipers on my jeep (black, not yellow or red-its fast enough!) tinking it would make them easier to clean-WRONG! it only took one mishap with a busted hose and shredding caliper paint everywhere. No tllin what the increased ethanol gas, whatever combo will do to that stuff...interestingly enough I did learn that brake fluid cleans calipers way better than brake cleaner!!
Mama lock your daughters up that wild bunch is back in town!...And them little girls get frisky when they hear that race-car sound!
Old 10-17-2010, 12:04 PM
moneymanager's Avatar
Truly poor idea. Dissolving paint in everything. A nightmare. And they will look nice for about 3 days, the time it takes for gas to leak out of them as it always does.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 10-17-2010, 12:20 PM
RETIRED
Joe Bob's Avatar
Not a good idea for a lot of reasons...
2012 ML350 3.0 Turbo Diesel
Old 10-17-2010, 12:29 PM
Ok, thought I'd see what experiences people had. Maybe the best idea is to clean them and give them a quick polish with mothers to help keep them clean.
Old 10-19-2010, 08:43 AM
If you take a q-tip with a bit of lacquer thinner to them every month you can keep them looking pretty good.
jhtaylor
santa barbara
Old 10-19-2010, 09:24 AM
If you used a 'special' paint like Imron and allowed it to harden for a couple of days it would stand up to just about anything-but the cost, the trouble...
Aston Martin and Rolls Royce used to have black painted SU carbs-I think it was a type of baked enamel. Looks very nice when new but looks like sh** after a few years.
Too many cars, not enough moolah...
Old 10-19-2010, 10:34 AM
I used a por-15 enamel that paints like glue and flows great so it can be done with a brush. Gotta take carb apart or it'll be glued together big time. A hammer and chisel will be needed to chip it. I just shot and have Imron clear and this stuff is better for the task
its called Pelucid and costs about $30-$40/pint
This pic is from june 2009 and maybe 5 years and 60,000 from when painted new. I just did 32 new 930 caliper hex bolts and expect same results. The carbs were not cleaned for the pic and needs only a wipe with gas or thinner once a year or two
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-19-2010, 11:04 AM
neilca's Avatar
I liked my painted. This paint was from Eastwood
Old 10-19-2010, 11:07 AM
Canuck_Targa's Avatar
Check out having the carbs re-anodized, I had a local shop do some parts for a restoration I was doing and it was under $100. They come out looking brand new, only problem is they will have to be disassembled. Not a big fan of painting them, one they look painted and second they only look good for a very short time, then they look worse than they did before the paint, but thats just IMHO.
Old 10-20-2010, 07:12 AM
maybe read my above post again
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-20-2010, 12:06 PM
Ronin
Do you have any more pictures of that engine you could post? Please
1982 SC
Old 10-20-2010, 12:57 PM
Originally Posted by Cdnone1 View Post
Ronin
if it's not on my computer now it'll be there if you want something specific
what kind of pics?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-20-2010, 01:46 PM
I would like to see more of the "electronics board " it looks like someone fabricated
1982 SC
Old 10-20-2010, 01:49 PM
Zeke's Avatar
That's Ron's. There is a whole thread about it, but it's an old one. Use his name and "wiring" as search terms.
Old 10-20-2010, 02:35 PM
thx Milt for helping me out. I needed a few minutes to get my act together.
anyway here's a couple of old threads with a lot of info and old wire covering.
MSD/Crane Mounting Locations
http://forums.pelicanparts.com/porsche-911-technical-forum/229418-whats-best-way-run-additional-switched-power-engine-compartment.html
The pic below is 2009 and has the double wall shrink tube
early install perforated sheet pics show the 1/4" gas hose liner and the safety wire attachment
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-20-2010, 02:55 PM
I did read your post, and it looks as if you found something that works. All I am saying is in my experience I have seen way more that don't look good a year after they are done than do. Anodizing makes them look as they did from the factory and does not add material to the surface, just giving options and my poinion. To me they still look painted.
Old 10-20-2010, 03:09 PM
every one i've ever seen looks like crap soon after being put in use except mine
Anodizing is good for around a few months around here
peace
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-20-2010, 03:31 PM
I am 1000 miles form any coast so I don't have to deal with that salt air. Por-15 is good stuff and it sticks like S#%T to shorts, so if anything is going to work it will be that stuff.
Old 10-20-2010, 03:59 PM
