dsmyth's Avatar
Transporting a 911 on a dolly???
I just bought a 95 993 (c2) to move in with my 85 and was considering bringing it back on a dolly for 600 miles. I would presume that I should back it on? Has anyone done this and is it a wise transportation option. Do I put the steering lock on or just leave the key in to ensure it doesn't lock. Thanks Doug
Doug
97 C2S 993(last one)
95 993 cab- 85 911 M491
87 944 Turbo- 70 914-6
63 911
Old 10-18-2010, 07:57 PM
Formerly known as Syzygy
Canada Kev's Avatar
Rent or borrow a trailer.
Kevin
Old 10-18-2010, 09:04 PM
LakeCleElum's Avatar
Just did it a week ago shuttling my '73.5 and '69 between 2 houses. Towed one each way (90 miles) over a mountain pass with a Toyota V6 P/u. Worked very well. Load facing forward, front spoiler is too low to backwards.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-18-2010, 09:18 PM
I did an SC targa one time on a dolly and it broke the windshield, flex stress
Bruce
Old 10-19-2010, 02:42 AM
cabriobrad's Avatar
Brought mine from Orillia,ON to Haileybury,ON(400Km) on a dolly like below...with a mini-van. Had no problems, but it was stripped also so I'm sure that could make a difference. Just make sure the area that I have circled has clearance. Mine didn't have much and scared me a few times, but only left a very small scratch on the underside that is barely noticeable. Even less so now that I touched it up.
1968 911L #11810584
We first met in '92...now I own you!
Old 10-19-2010, 03:01 AM
scarceller's Avatar
I have done this several times. Do load the rear on the dolly, lock front steering in center position is fine.
If you load the front on the dolly not only will you stress the drive train but you will apply much more stress to the chassis because the rear is much heavier than the front and the tow load will be applied through-out the chassis.
When you load the rear on the dolly, 70% or more of the tow load is directly on the dolly and thus not stressing the chassis.
One more thing you could do is crank up the front suspension via the adjusters at the A-Arms but if you do this you will need to re-set the front ride height after. If you decide to do this it's best to jack up the front of car to adjust the ride height, best to adjust the bolts with no weight on the wheels if you are going to crank up the height to max. Count the turns so you can get back in the ballpark later.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 10-19-2010, 05:59 AM
Driver8's Avatar
Originally Posted by syzygy View Post
rent or borrow a trailer.
+1
Old 10-19-2010, 09:45 AM
