H1 adjuster device?
I'm looking for one of the female h1 adjuster devices like the one circled in the photo. Posted on the parts list but no response. I have done quite a bit of searching but no luck. Maybe you have an old H1 laying around that you can part out?
Tsunamiboy
Tsunamiboy 1979 911 SC (3.2L) 1997 Boxster 986 |
Hardware store..
Long screw or threaded rod. Rubber tubing (landscape watering tubing). "push" nut/washer or nylock nut(s). .0625" steel sheet, "nibbling" tool, drill, drill bit, tap. Drill/tap the holes first and then use one of the OEM parts as a template for nibbling. If I remember correctly I had to drill out, to a slightly larger size, the hole the rubber grommet was "mounted" in. In my case all of the rubber grommets had brittilized and were coming apart. Last edited by wwest; 10-19-2010 at 09:18 AM.. |
HID bi-xenon Projector conversion, Ebay.
AutoBahned
there is an old thread on Early 911S bbs showing one person's struggles with this
be aware their search engine is less capable than Pelican's so it may take some extended reading; also H1 and H-1 may both need to be used as terms |
