-   -   starter issues in a 2.7 to 3.2 engine swap (http://forums.pelicanparts.com/porsche-911-technical-forum/571216-starter-issues-2-7-3-2-engine-swap.html)
jld 10-22-2010 05:07 PM
I switched from a 2.7 to a 3.2 useing my 76 915 trans and a sachs alu flywheel assembly I had put on the old engine. The starter spins but will not engage the ring gear. the total travel of the gear is approx 4cm. I measured the distance from the face of the starter mount to the face of the ring gear and it appears I need about 6cm of travel to completely engage the starter and ring gear. Is this a starter issue or does it relate to the flywheel assembly?
Would appreciate any Info.....thanks
jld 10-22-2010 09:28 PM
Are the starters the different on a 3.2??
Oh Haha 10-23-2010 04:53 AM
The starter is the same for 74-89 but the starter RING GEAR is different. That might the issue holding you back.
I don't know the exact differences but here is info from the pelican catalog-
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
jld 10-23-2010 05:17 AM
Thanks Wayne......Looks like my engine is going to see the shop floor again:eek: I thought I had it all sorted out seeing as how I as reuseing the Sachs flywheel setup, but something is different in the depth
jack
1976 TN Porsche 10-24-2010 06:45 PM
I too Replaced my 2.7 In my 1976 Porsche 911S with a 3.2 I had to use a 9 BOLT 3.0 Flywell. It works just fine.
john walker's workshop 10-24-2010 07:46 PM
well, maybe the ring gear is not there. the teeth on a 3.2 flywheel are not starter teeth. they are there for the sensor. the starter teeth go on over the pressure plate. just a wild guess.
yelcab1 10-24-2010 08:55 PM
More than a few persons have made that mistake.
jld 10-24-2010 10:29 PM
John....it appears that is exactly what I did wrong. I only have one set of gears on. The next question is does the order the gears are installed matter or can they only go on one way?
jld 10-24-2010 10:30 PM
By the way...THANKS!!
