Turn signal stalk switch...
'88 Carrera Special Edition:
Everything on the turn signal stalk works, Left, right, low/high, except headlight flasher. Circuit 30, horn, hazards and parking lights all work with key off/out. Unless advised otherwise I'll tackle the turn signal switch assembly first. |
check the relay for the flasher.....you may need to remove the wheel and switch cowl
No relay involved according the schematics provided by our host. Headlight flasher power, circuit 30, goes directly to the turn signal switch assembly and from that directly to the high beam connection.
I'll have more time to look later, but there is a thread with photos about cleaning the contacts. That is likely the problem. The contact when you pull back is likely dirty/corroded. Getting the steering wheel off is fairly easy (Need 27mm deep socket). I just had a little trouble getting it back on. (Nut is hard to thread back on).
I had to adjust mine when the high beams would come on when I went over a bump in the road |
Here's the link I was referring to... Hope that does it for you. Let us know.
http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html |
| All times are GMT -8. The time now is 04:18 PM. |
