Send a message via MSN to 911Jarle
My first 911 valve job
Hello guys!
Getting the 911 on my two post lift this friday, to do a valve adjustment and oil change... How many hours should I reckon to use on this?
I'm starting friday evening, needs to be done before monday morning work time
Looking forward to working on the car!!
Done valves on my Lambo and Maser, so technically I don't think there will be issues.
Thanks guys..
Cheers, Jarle
Old 10-19-2010, 02:01 PM
Friend of Warren
Your first time, doing it right and double checking everything: 3 hours.
Kurt V
Old 10-19-2010, 02:32 PM
Thanks! Will certainly double check everything. Sounds like I have plenty of time then.
Got the special feeler, gaskets and all..
The aircon compressor needs to be moved out of the way I guess, looks kind of cramped in that area...
Will read through the Pelican articles on it!
Thanks..
Cheers, Jarle
Old 10-19-2010, 02:49 PM
rallen911's Avatar
Jarle,
It sounds like you are more experienced than I am, so I am guessing that you will do better than I'm doing.
I haven't had any real problems, just a lot of questions. I'm in about 8 hours, so far. I have lots of interruptions too, though.
Good Luck!
- Rob
'86 911 Carrera Coupe
Old 10-19-2010, 03:10 PM
LakeCleElum's Avatar
2 to 3 hrs; more toward 3 for the 1st time. Just so you have your lingo correct, you are doing a valve "adjust", not valve "job". Valve job indicates pulling the heads and all.......Good luck.......
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-19-2010, 03:33 PM
muck-raker
kidrock's Avatar
don't be surprised if it takes more than 3 hours. But if you've done Lambo and Maser valves, I'd imagine a P-car should be a fairly simple procedure.
Did you mention the year of your car? You will need to move the A/C compressor, and if you have a '84-'89, you'll need to remove the heater blower motor too.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-19-2010, 09:44 PM
Sorry, lingo problems. No valve job that I know of
Just valve adjustment...
If I reckong 5 hours, I should be on the safe side!
Cheers, Jarle
Old 10-20-2010, 03:00 AM
Hey!
It's a 79, so heater blower is situated in the left wing, out of the way.
Ac vompressor though, needs to be moved out of the way I think.
Thanks!
Cheers, Jarle
Old 10-20-2010, 03:01 AM
wannabee wannabee
WIL84911's Avatar
Scraping those old gaskets is the pits.... hopefully you won't have any like I did.
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 10-20-2010, 05:17 AM
burgermeister's Avatar
I took 6+ hours for my first adjustment ... and I got it wrong, so I had to redo it. It's a PITA, I don't care what anyone says. I can do it in 4 hours now ...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 10-20-2010, 04:55 PM
MindtrapX's Avatar
I'm due for one myself. Just got my ECM back a few weeks ago from 911Chips, now it's time for the caliper rebuild & vavle adjust. It'll be my first time as well. Let us know how it goes!
Kevin
'84 Carrera RoW Coupe
"I'd like to offer moral support, but I have questionable morals"
Old 10-20-2010, 06:14 PM
80-911SC's Avatar
my first took two weekends but i had issues, found a c clip in the cover that i had to figure out what it came from, wound up being the timing chain link, put the clip back and done, about 7k later and checked three time did last adjust in about 3
(in my first i also took out engine tin and a lot that didn't need to come out but
WHILE I WAS IN THERE ...... famous last words )
Old 10-20-2010, 07:32 PM
Detached Member
Hugh R's Avatar
Do the exhaust first at least you can see them and figure out what you're going to do blind on the intakes.
Hugh
Old 10-20-2010, 08:39 PM
rallen911's Avatar
I just finished my first valve adjustment. I've turned the crankshaft a few times now, and they are ready to be checked. I gave up on trying to find a "baseline" to figure out the feel, because they were all too tight to get the gauge into.
- Rob
Old 10-20-2010, 11:12 PM
Formerly known as Syzygy
Canada Kev's Avatar
I don't need to remove the heater blower on my '87, but the ducting does have to come out. Removes with one or two screws.
Kevin
Old 10-21-2010, 08:18 AM
Canada Kev's Avatar
Yeah, I had/have issues with that, too - just can't get the damn feeler back in after I remove it on a properly adjusted valve. The last time I did an adjustment, I used the back side method to check all the valves. I check them first so that I don't bother to "fix" something that's already adjusted properly, and then again after if I make changes.
Kevin
Old 10-21-2010, 08:21 AM
And don't be afraid to losen the adjustment to get the feeler in place, and then adjust. It will save you a bunch of time as well as blades on your feeler gauge.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 10-21-2010, 08:50 AM
rallen911's Avatar
On my '86, I had to "fold" the AC compressor onto the fender and removed the heat duct, but not the motor.
- Rob
Old 10-21-2010, 10:43 AM
gtc gtc is offline
abides.
gtc's Avatar
Mine almost always take more than 3 hours... but I like to take my time.
Graham
1984 Carrera Targa
Old 10-21-2010, 11:41 AM
Fairly simple job, but the hours are there. If done correctly, owners can save some significant dollars compared to a repair shop doing it. BTW, what's the going rate for reference purposes?
Sherwood
Old 10-21-2010, 11:55 AM
