-   -   Another, What's this on my Drain Plug.... (http://forums.pelicanparts.com/porsche-911-technical-forum/571538-another-whats-my-drain-plug.html)
DUK 10-24-2010 05:13 PM
http://forums.pelicanparts.com/uploa...1287965437.jpg
It is magnetic, brittle, curled and looks to have been sheared off the side of a bearing. Any guesses?
James Brown 10-24-2010 05:31 PM
If it's magnetic, it would not be a bearing or case. Looks like a bolt or stud thread. And the other thing is a U.S. 1986 dime. $0.10. have no idea how that got in the engine. Assuming it's the engine were talking about, same plug in the transmission.
DUK 10-24-2010 05:50 PM
Yes it's from the engine drain plug, not the trans. or oil tank.
warner53 10-24-2010 06:32 PM
Same year as my 911, could I have it?
Warner
:D
Grady Clay 10-25-2010 06:44 AM
My 2¢,
Looks like the ‘spring’ from around a valve stem seal.
It appears somehow ‘straightened out’ in its travels.
Best,
Grady
cgarr 10-25-2010 06:57 AM
would it happen to be .004 thick?
DUK 10-25-2010 02:59 PM
James- I believe bearing shells are made of magnetic steel, right?
Warner- No it's mine, you can't have it. Besides it out of my 3.2l
Grady- I'm pretty sure it's not a spring, it's too flat. But I see where you're going.
Craig- It's .0065 thick, why?
cgarr 10-25-2010 03:01 PM
Maybe a piece of feeler gauge?
Scott R 10-25-2010 03:04 PM
Looks like someone drilled something out at one point and that's whats left over.
