Tach with EDIS
Anyone out there with a quick reply on how to hook up the 80SC tach to EDIS ignition ?
I managed to connect the ignition easy enough but how to get the tach working remains unclear.
Grateful for any advice
Rgds
80SC (ex California)
Old 10-25-2010, 12:30 AM
Drivin' Miss Daisy
benzyne's Avatar
there is a signal wire off of EDIS that connects to the tach lead and drives the tach without any problem. I'll look into it after work for details.
58 VW Split Window Bus - Porsche Powered
78 911SC Turbo Look - Megasquirt II, EDIS, 964 intake
92 964 Turbo
Old 10-25-2010, 06:51 AM
Drivin' Miss Daisy
benzyne's Avatar
I found this on the web ( from here Megasquirt MSEXTRA and MS3EFI support forum • View topic - Dual EDIS 6 wiring ):
pin 1 = PIP (raw signal to MS)
pin 2 = IDM (tach signal)
pin 3 = SPOUT (modified spark angle from MS)
pin 4 = Ignition Ground
pin 5 = Crank Sensor -
pin 6 = Crank Sensor +
pin 7 = Shield Ground
pin 8 = Power
pin 9 = Ground
pin 10 = coil A
pin 11 = coil C
pin 12 = coil B
92 964 Turbo
Old 10-25-2010, 07:26 AM
There should be a purple wire with a black stripe you connect to PIN 2 on the EDIS which may vary in color depending on what car the EDIS harness came from. Look on the back of your tach and on the bottom there will be a positive, negative and the tach signal wire. Mine was purple, but I think it is the same for the SC. Find that wire in the harness coming into the engine compartment and splice that into PIN 2. Simple as that.......
Kevin
2000 Boxster S
2013 Golf R
1999 911 C2 Aero
Old 10-25-2010, 08:17 AM
Thanks. Just didn't know whether the EDIS tach would drive the SC tacho. I've seen several posts concerning this.
Rgds
Old 10-25-2010, 09:30 AM
I have an SC tach in my 71 with EDIS and it works great.
Kevin
2000 Boxster S
2013 Golf R
1999 911 C2 Aero
Old 10-25-2010, 09:57 AM
