sunvisor screw hole stripped
The mounting hole for the screw of the sunvisor pivot is stripped. This is the female threaded portion underneath the headliner (something I can thank the previous owner for). Short of pulling back the headliner, are there any options for addressing this..? Slightly larger screw?
Kurt |
This is not an area put under much stress, so you may be able to get away with wrapping the original screw in plumbers tape.
2005 Porsche 911: 997S, supercharged to 530HP 1987 Porsche 911: Concours prep OEM guards red on black |
Wash. State
I think tape is a fine idea, keeps orig. parts in place, though it's only hardware. However, I did put a new one size larger screw in my car (pass. side would not hold) and it looks orig. and works fine; black phillips head from Ace Hardware.
Thanks for the ideas guys...
Any more would be appreciated
Kurt |
Home of the Whopper
metal puddy. You can get a tube from most flaps and even wal mart. Once it hardens you can drill and tap it.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Fill the hole with JB Weld epoxy putty (putty...not the liquid stuff in the individual tubes). Allow it to harden completely, and then drill and tap.
My $.02. HTH!
1984 Targa |
Sometimes just running the proper sized tap through will give you back enough threads to hold a new bolt, then just put some blue Loctite on it and fuggetaboutit! If completely stripped I would drill and tap to the next size and be done with it.
Gary R. |
Not sure if the 911 sun visor mount is similar to the Boxster's but the threaded female portion of the visor mount on the Boxster is a common failure. One solution is to replace the original threads with a nutsert.
randrcenternuts - mikefocke2 I was able to do a temp fix on mine using black silicone sealant, and it has lasted several years. At some point I'll probably go the nutsert rout if needed. Aron
Aron 1997 Boxster |
