-   -   Can anyone tell me what hole to use? (http://forums.pelicanparts.com/porsche-911-technical-forum/571817-can-anyone-tell-me-what-hole-use.html)
LM3929 10-25-2010 08:34 PM
I have an 83 SC that is slowly going back together and I don't remember which Engine tin hole that I should be using to run the left heater hose in?
It is possible that I should have used a solid plate on the left side as well.
Is it possible to get a picture of someones 83/83 SC showing the hose/engine tin
Thanks Lorne M.
http://forums.pelicanparts.com/uploa...1288067473.jpg
http://forums.pelicanparts.com/uploa...1288067524.jpg
http://forums.pelicanparts.com/uploa...1288067585.jpg
RSBob 10-25-2010 09:08 PM
Just have to wonder how many looked at the post subject and thought 'would really like to reply, but not goin there'?
70SC 10-25-2010 10:14 PM
yes you should have only the sleeved one on the left side. the hole is on the right .
Walt Fricke 10-25-2010 10:15 PM
I think the short plate with the hole goes on the right side, and the short solid plate on the left.
Try that.
D911SC 10-26-2010 01:58 AM
Try that.
This is how mine is (an 83). The heater hose connects to the sleeved hole and the small plate is blank (solid) for the left side. The right side has the small plate with the hole that the hose goes right through to the heat exchanger.
Swap the small plate and it should make sense.
T77911S 10-26-2010 03:33 AM
"Can anyone tell me what hole to use? "
come on, your killing me!
bart1 10-26-2010 04:40 AM
http://i449.photobucket.com/albums/q...2/Quagmire.jpg
bourgeois911 10-26-2010 04:56 AM
If the first one you try don't work, try rolling 'er over.
rattlsnak 10-26-2010 07:00 AM
For the models that have the heater bypass installed, the heater hose goes through the hole closest to the chain covers. (the hole on the left in the top picture). For your application, its as stated above. Solid on the left.
LM3929 10-26-2010 10:41 AM
Thanks Guys, I purchased a solid plate off of the site to replace the left side extra hole.
I have looked thru Bently, the factory manuals even Waynes book but no where is any pics of that particular area.
Thanks again Lorne M.
