Engineer of profanity
924CarreraGTP's Avatar
MFI fuel pump for carb not working.
Justin here, I pulled my MFI fuel pump out of my 1970 911T. With the help of a thread called MFI Open Heart Surgery I removed just the pump off of the front. I sprayed carb cleaner into the pump and spun the shaft and the motor runs with a battery.
The problem is that after I reinstalled the pump and o-rings, the pump still doesn't work. The the motor in the pump spins up good, but the pump isn't sending fuel to the carbs.
Under the pump mechanism on the front of the pump there is a steel ring to hold the star wheel and rollers in. The plate has a small indention on one side. Which way does this indention point?
I should have marked the side of the pump to the relation of the ring and the pump before disassembly but I forgot. Any pictures of each side of one of the pumps or just personal experience would help me.
Thanks pelicans. You guys are a super forum.
Justin
Old 04-16-2011, 12:25 PM
The indention is on the outside of the steel ring plate under the pump and the 1st o-ring. All I need to know is which way to point the indention.
Old 04-16-2011, 12:31 PM
Information Junky
island911's Avatar
I just took a pic of one a couple days ago...
the notch
Old 04-16-2011, 12:34 PM
Information Junky
island911's Avatar
you may have missed my edit and second pic. ... the indentation is up.
Old 04-16-2011, 02:11 PM
Yes this must be a rebuilt pump? The ring behind the pump is square on this pump. Mine is round and it has an indention on the outside of the ring. It doesn't look to matter where it is, but my pump won't work even though it spins up freely on a battery. I wonder if it's the pump valve inside the pump itself. I cleaned it with carb cleaner too but still no pumping.
Old 04-16-2011, 02:14 PM
Oh, right on! I see the indention! Maybe this is why my pump won't work. Back to the shop. Breakdown #3 maybe she works the next time. The third time is the charm I hope.
Old 04-16-2011, 02:17 PM
Information Junky
island911's Avatar
the pic above is a new (old stock) pump for a '73 911S (MFI).
The operation of these type of pumps is simple --constantly squeezing the fluid to the outlet- but if the inlet & outlet are in the wrong place, it won't pump. ...if the eccentric opening is in the wrong place, it won't pump
sounds like you have it now.
Old 04-16-2011, 02:21 PM
Thanks so much sir! Maybe this will get her juices flowing again.
I would advise anyone trying to undertake this job to service the pump half.
Spray some carb cleaner in the housing hole and spin the shaft by hand 5 or 6 times. Then hook your battery up and see if it spins.
You might not even have to service the motor.
Also, the o-rings are not rubber and look to be manufactured flat. If the the pump half is not leaking when you take it apart, put some WD40 on the seals to swell them up and put them back in if you have to. It's a little harder to find the seals than you think.
Of course you will have to monitor the pump for leaks often because there is no telling how long this will stay sealed.
Old 04-16-2011, 02:37 PM
Oh and tighten the #%^* out of it if you use old o-rings. The pump half was on mine very tight when I first took it off.
Old 04-16-2011, 02:41 PM
