Mike80911's Avatar
Power seat conversion
Hello everyone I was thinking of changing my 80 SC over to power seats out of an 85 I have two questions before I spend the money 1 Do the tracks line up or will I have to do some welding? 2 When I wire up the seats do I simply provide a hot lead and a ground to the motors on the new seats or is there something more to it? Thanks for your help
Old 10-29-2010, 01:03 PM
jtfreels's Avatar
The seats will fit just fine, no changes necessary. Be aware that that the power seat is a bit higher if that matters to you.
Wiring is simple though I would suggest you had a fuse, just in case.
I have 944 seats in my 82, since I rarely change the setting I just hooked up a temporary 12 volts, got it were I wanted it and left it.
Jay
2002 Boxster Speed Yellow
Old 10-29-2010, 01:39 PM
AutoBahned
RWebb's Avatar
power seats are heavy - why do you want them?
Old 10-29-2010, 01:41 PM
wwest's Avatar
The nice thing about power seats is that you can more easily change your seating position during a long drive.
Old 10-29-2010, 05:36 PM
Mike80911's Avatar
Power Seats
Not really worried about the weight issue my car is just a weekend driver the seats in my car now are destroyed and rather then rebuild the seats I found a decent set of power ones so thought why not if they fit might as well switch and as said here they are easier to adjust. Thanks for the advice I figured I would put a fuse in the hot side on each sounds like a good idea
Old 10-29-2010, 05:44 PM
