Question for Weber Experts
While rebuilding my 40IDA's today I noticed on top of one of the floats there is a small dent (half size of an pencil eraser), no hole, should I change it or is it ok?
Old 10-31-2010, 10:31 AM
1QuickS's Avatar
Check for leaks by putting into bowl of warm water and check for escaping bubbles. If the shape is generally OK then reuse it.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 10-31-2010, 10:37 AM
Here is a photo
Old 10-31-2010, 10:59 AM
goldsc78258's Avatar
Send a message via Yahoo to goldsc78258
webber
Like quick said if there is no leaks on the float then is fine to reuse, the dent is on the top and won't affect the float level at all. I've seen a lot worse
Hope this helps
Old 10-31-2010, 11:32 AM
AutoBahned
RWebb's Avatar
looks ok - any problems in operation?
can try magnification for visual exam or pull & test as per above
