Hazard Light Switch Install
I needed a new Hazard switch, which I have, but can not get it to plug back in, the receptacle moves every time I try to put it in place. Any tips on this?
Thanks! Rod |
So, I pulled it apart, and got the switch in, but now i screwed something else up! Now the fan controls are not tight up agaisnt the hazard and defrost switches! Looks like it slides in to it, but I could not get enough slack to pull the knob area forward to re slide it into the grooves! HELP!
Rod |
Wow, no one?!
Need some help people! ;-) Thanks! |
Some pics of what you are dealing with might help.
I looked at your post last night but don't have the same setup so I can only bump your post. |
| All times are GMT -8. The time now is 11:06 AM. |
