Send a message via AIM to NoLift911
Picture of stock horn setup on 84 Carrera?
So I took my horns off about 5 years ago - have all the brackets and parts etc and trying to figure out how they mount and where ( I know passenger side wheel well) - anyone have a stock pic (all I could find in the search was "relocating" fromthe stock location. I have the 28 row brass cooler, not sure if the install is different on the "Carrera" cooler setup.
Thanks -
Jeff
Old 11-01-2010, 12:20 PM
Make Bruins Great Again
Por_sha911's Avatar
The horns are underneath the headlight in front of the RF wheel. The Bentley's Bible (actually Manual) says to remove the front bumper. Not needed. If you get under the right front of the car and look straight up, there should be a place for one bolt to attach the bracket that holds the hi and lo tone trumpets. It takes about 1 - 1.5 feet of extensions to reach it. Getting a pic of that is going to be tough since its up high and dark. I may have a spare bracket I can snap a shot of if you need it.
This is from Bentley's. The arrows point to the wires to connect the horns.
Joe
Old 11-01-2010, 02:33 PM
