m1franck's Avatar
Will a factory early 911 LWB sway bar fit a SWB car?
Can anyone tell me if this LWB sway bar will fit a '68 SWB car? I know a factory bracket will need to be welded to the rear subframe to attach the main mounts, but what about the length of the arms and the attachment point to trailing arm? Thanks
Here's the link to the part that we have a question about:
FS: Rear Sway Bar 15mm with Mounting Hardware and Weltmiester Bushings
Old 11-03-2010, 07:49 PM
Send a message via Yahoo to Larry_Ratcliff
It will work. However, on top of the mount to the body you will have to put a sway bar attachment on the banana arm too. I did the same once upon a time with my '67. I did not have a factory rear sway bar...
Old 11-03-2010, 11:15 PM
Porsche Nut
merbesfield's Avatar
My banana's have the nub so I am good there. Just wanted to be sure the width is the same.
Old 11-04-2010, 05:59 AM
Mark S
If you have the banana attachments that is the BIG deal . You can weld on factory or aftermarket frame attachments no problem, go for it. Note you will need to balance out with a 15+ front.
Old 11-04-2010, 08:15 AM
