SSI heat exchangers = no cat conv = bad news for CA resident?
SSI heat exchangers + aftermarket exhaust = nice mod, nice gain in performance, but requires removing the cat....so as a CA resident, I should forget about it right? It's not worth the problems that may arise with emissions testing, right? Unless the smog guy mistakes the stainless steel SSIs as some sort of cat, I'm not going to pass the visual, am I correct? And if I do pop SSIs on, do I would have to pop my original equipment every 2 years......
I've read just about every "smog" and "SSI" related post on this message board, and that is the conclusion that I came up with. If someone can tell me that I'm wrong, I'll be very happy to listen.
Thanks,
SchnellBoy
Old 01-19-2002, 10:22 PM
Hilbilly Deluxe
emcon5's Avatar
See this thread, from this evening:
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?&threadid=57347
What a lot of people do is swap back the stock exhaust every 2 years.
Tom
82 911SC Coupe
GTI Cup #43
Old 01-19-2002, 10:26 PM
Clark Griswald's Avatar
The SSIs look suspicously like cats. And the typical smog inspector has no idea what those wacky rear engine air cooled jobies are supposed to look like. Know what I mean, nudge nudge, wink wink.
Clark Retired, I'm now posting under my real name
Chuck Moreland
Day Job - Elephant Racing
Basic Transportation - '86 Cab - "Sparky", '77 Targa - "The Peaper"
Old 01-19-2002, 10:41 PM
schnellboy,
why go with the ssi,s just do a cat bypass and sport muffler,
almost the same gain and alot less trouble especially when you have to change back every two years.
slant nose in kansas
whats smog?
Old 01-20-2002, 08:31 AM
RETIRED
Joe Bob's Avatar
Check out my previous post....mine just passed. BUT...it has a smog pump that most don't have on the SC. It was added when it was Federalized after import by it's owner.
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=57347
As long as you can convince the tech that it has a cat pipe(s)....AND your emissions are below the max, you will pass.....
YMMV
2012 ML350 3.0 Turbo Diesel
Old 01-20-2002, 08:48 AM
Hilbilly Deluxe
emcon5's Avatar
Which is in itself pretty wierd. US 911's in 83 didn't have a smog pump, did they? My 82 doesn't have one.
I wonder why they did that.
Tom
82 911SC Coupe
GTI Cup #43
Old 01-20-2002, 09:34 AM
RETIRED
Joe Bob's Avatar
God who knows why they added a pump....it really does not do much.
I have put it on the tester without it tuning (diconnected the belt) and the changes are very insignificant....but that sticker in the door says it HAS to be there, so when it is tested or if anyone asks....it's there.
Old 01-20-2002, 09:40 AM
Thanks for the replies. I'm assuming that a 911SC with SSIs and an aftermarket exhaust (Bursch) will pass everything but the visual. I've read the thread about techron, about low grade vs high grade gasoline, and so on. I'm pretty buddy-buddy with the local Chevron station mechanic, so I'm pretty sure he'll give me an A-OK on the smog check.
Old 01-20-2002, 07:11 PM
