New 911 owner 1986 Targa
Living in upstate NY I need to put the car up for winter, Antthing I should know about before putting it away???
Thanks Guys,
Bob
Old 11-04-2010, 07:51 AM
Make Bruins Great Again
Por_sha911's Avatar
There are many things to consider:
-Fuel: winterize with Stabil marine.
-Battery: remove or put a trickle charger on it.
-Oil: Change the oil before you put it to bed. It will get rid of water, acids, etc that can do damage. Some folks change it just before they tun it in the spring but I'd rather have clean oil in it all winter.
-Critters: they love to nest and chew. I use a multi-pronged attack with traps, glue boards, and poison (no pets to worry about).
-Consider doing large projects that require an engine drop like trans rebuild, fixing oil leaks, etc. This means more time on the road when spring finally shows up.
-Be prepared for withdrawal symptoms. Stay close to Pelican to keep your condition under control.
On a side note: I went to SUNYA and had friends from Syracuse and Buffalo (what a god-awfully cold place). Are you in Seneca Falls?
Joe
Old 11-04-2010, 09:08 AM
winter
Winter's Avatar
This is a serious issue. You may consider instead of storing your car for the winter, that you move your entire household to a climate that allows for year-round driving. It saves a lot of time prepping your car for storage.
Tom
'76 Targa
Old 11-04-2010, 10:59 AM
