-   -   speed bump=no run (http://forums.pelicanparts.com/porsche-911-technical-forum/573709-speed-bump-no-run.html)
Cdnone1 11-05-2010 11:40 AM
speed bump=no run
I drove over a speed bump going to pick my son up last night and the motor just quit after about ten feet. I'm thinking must be electrical in regards to the fuel system. The car has plenty of electrical to the lights starter etc.
I was going to check the fuel pump relay (even though it is new along with the fuel pump I installed a few months ago) then pull an injector to see if it's getting fuel.
Anyone else had this happen and would like to chime in and maybe save me some time I would appreciate it
Gemballa2006 11-05-2010 12:10 PM
Probably knocked a ground off. That's what I would check first
Cdnone1 11-05-2010 12:11 PM
Which ground?
James Brown 11-05-2010 12:35 PM
LOL that's the question!! Go through a no start check list and see what you find, ignition, fuel pump, ign. switch, battery, fuses, relays. Pull the relays and check for corrosion and twist fuses for the same reason. Bumps might dislodge both power and ground throughout the car.
b rock 11-05-2010 12:42 PM
check the fuel relay in the front fuse block. it may have been jarred loose.
Bob Kontak 11-05-2010 01:26 PM
+1 on fuel relay - Closest one to the master cylinder.
SCOTITUDE 11-05-2010 04:56 PM
+2 BTDT
when i was a new owner before the internet. a day of scratching my head and wondering what i got myself into. pcar friend came over to help. i pleaded my case and he opened the hood, pushed the relay back in that had come half out and she started. cost me a flatbed ride home. wire tie the relay into the socket to keep it from bouncing out.
Rich Lambert 11-05-2010 04:59 PM
Check for loose screws on the fuse holders too.
Cdnone1 11-05-2010 05:51 PM
So I had a few minutes to look at it this evening before the sun went down. (The car was towed to the street in front of my house.)
I replaced the fuel relay with what was a good relay months ago that I just replaced when I put in the new fuel pump. Checked the fuse, cleaned up the contacts. Opened the engine compartment. Turned key on and can hear the CDI box buzzing. Lifted plate in the airbox and made the correct buzzing sound.
Pulled the #1 injector line at the injector, put into a safe container turned key on lifted air plate and no gas coming out of injector line.
Any idea 's where to start in the morning. Anyone know how to check the relays to see if there good even though I don't think both would be bad.What about checking the relay mounting holes on the fuse box. I'd like to take the car to a football game tomorrow afternoon so I would like to fix this quick
Thanks for the input
Joe Bob 11-05-2010 05:58 PM
What engine?
Cdnone1 11-05-2010 06:04 PM
Sorry guys
It's an 82 SC with (obviously) a 3L
Joe Bob 11-05-2010 06:09 PM
OK....you have fuel, pump running, got spark?
If so, tried popping up the flapper valve in the air box?
Cdnone1 11-05-2010 06:12 PM
Originally Posted by Cdnone1 (Post 5657829)
No fuel at the injector line, lifted flapper
Joe Bob 11-05-2010 07:08 PM
Is the fuel pump buzzing when the ignition is turned to the on position?
James Brown 11-05-2010 07:28 PM
Hear that??? The sound of silence, fuel pump that is...
boyt911sc 11-06-2010 04:44 AM
CIS troubleshooting.........
FP's for SC's don't run at ON/RUN position!!!!!! And if it does, there is inherently wrong in the wiring set-up. Test the FP and FP relay separately to determine if they are good.
A very simple way to test the FP is by jumpering terminals #87A & #30 (FP relay socket) with the ignition @ ON/RUN position. If the FP fails to run, the're several possible causes to check; wire connections, ground supply for #85, bad FP, etc.
Lastly, check if the FP relay's magnetic coil activates when energized or get a known good relay for the FP test.
Tony
1990C4S 11-06-2010 05:06 AM
Correct. But his fuel pump should have run when he lifted the plate.
So if you can't hear the pump running you need to do what Tony says above. Either figure out if the relay is energized and closing, or slide under the car and measure the voltage at the pump with the plate lifted.
Possible issues: bad pump, no ground on pump, no +12V to pump, (possibly the air flow switch is preventing the f/p relay from coming on? IIRC)
Cdnone1 11-06-2010 04:22 PM
Crap
I can here the fuel pump running when I lift the plate.
Pulled the #1 injector line, lifted plate and no gas.
Pulled the line from the fuel accumulator to the filter and hooked up a line. Lifted plate and no gas!
Got to be a bad pump , right?!
I just replaced this pump 7 months ago!
Damn. The first pump looked like it lasted 26 years and the second one lasts 7 months!
And I just filled the tank!
AAARRRGGGGG
Joe Bob 11-06-2010 04:43 PM
The pump could have knocked something loose in the tank and clogged the line.....btw, I still run my old SC fuel pump even though the 3.6 uses a lower pressure. It runs all the time when the ignition is on. In an earleir post I DID suggest lifting the flapper, just wasn't clear in my followup.
boyt911sc 11-06-2010 07:34 PM
FP test.........
Originally Posted by Cdnone1 (Post 5659046)
Crap
AAARRRGGGGG
Steve,
To test your FP, you need to measure the fuel pressure or the volumetric rate per unit time and the current draw. But most important of all, there should be sufficient free flow of fuel from the tank to the pump.
Even a good FP would fail the volumetric flow test if there is severe flow restriction from the fuel tank outlet. Assuming that the fuel is flowing freely out from the fuel tank outlet, a good FP should be able to develop the required minimum flow rate (example: 1 liter/30 sec.) as per specification.
Bench test the FP, before condemning it as defective FP. I like to use both fuel pressure and current draw tests for determining the condition of a CIS FP. BTW, do you have a Bosch FP? Keep us posted.
Tony
RSBob 11-06-2010 08:01 PM
In a completely different direction - look under your dash and make sure all the plug connectors are in place and snug.
A year ago I hit a big pot hole and everything stopped immediately. Since I was on a major highway at rush hour, I had it flatbedded to a local shop where the owner said - I can fix this in 15 secs. He ran his hand under the dash, found the loose connection, popped it back in and the car fired right up.
Cdnone1 11-06-2010 09:59 PM
Thanks guys
Right now I have electric to everything and I can hear the pump running but I am getting zero fuel out of the accumulator. Not even a drop. If the pump was obstructed I should be getting a little gas out of it
James Brown 11-06-2010 10:02 PM
the pump can fail (not pumping) anytime. At this point, remove the pump and bench check it or just replace it. I know they should last forever but, well, it's a mechanical part, subject to failing at any time.
1990C4S 11-07-2010 05:17 AM
Crack the incoming line and make sure fuel is getting to the pump now.
kidrock 11-07-2010 08:14 AM
FWIW, I once jumpered my DME to find out if my pump was causing a "no-start" issue. Once jumpered, I could clearly hear the pump "running", but was not getting fuel to the throttle body.
I went ahead and replaced the pump anyways, which solved the problem.
Just because you can hear the pump motor whirr, doesn't necessarily mean that the pump is doing it's job.
Cdnone1 11-07-2010 09:21 AM
I will check the line to the pump when I pull the pump Monday. It says it is has a 24 month warranty and it is well under that. I bought it at Pelican but I have never had to warranty anything with them before.
Cdnone1 11-11-2010 11:36 AM
It was a failure of the fuel pump.
I had just installed a new Bosch fuel pump 8 months ago and it failed without warning.
I couldn't believe that it would be the pump but after I eliminated everything else it was the new pump.
Pelican says it is warranting the pump.
What a pain in the a$$
Bob Kontak 11-11-2010 03:13 PM
When you lift the air sensor, does it make a screeching sound from hell?
Check this video about 10 seconds in.
YouTube - Comprobando pulverizacion , goteo y caudal inyectores mecanicos K-jetronic
kidrock 11-11-2010 03:45 PM
That's actually good news, Steve. Pretty simple fix, but I realize it's a pain in the azz to replace something that should be rock steady when new. Life happens.
