Idler arms spacers..
Does anyone know the dimensions on the idler arms spacers needed when upgrading the chaintensioners to carrera oil-fed.... but keeping to older-style idler arms?
Inner/outer diameter and height? Thanks a bunch :-) |
This is the production part for it 930.105.513.00
Bruce |
The thickness is 10mm. Don't know the other numbers off the top of my head.
Mark S. '70 914-6 |
Thanks Mark... how does inner diameter: 15mm outer diameter 25mm sound?...
I don't have a spacer, but measured the end of a tensioner and got 15mm and 26mm for ID and OD.
Mark S. '70 914-6 |
