930cab89's Avatar
How can I remove the throw out bearing from the clutch pressure plate?
I would like to change the throw out bearing on my G50 and I can't figure out how you remove it from the pressure plate. Does someone know how to do it?
Old 10-30-2010, 02:22 AM
fred cook's Avatar
TO Bearing..........
Looking at the inside of the pressure plate, you will see a wide snap ring around the throw out bearing. You will need a set of snap ring pliers that will expand the snap ring. Also, once you get it off the pressure plate, be sure to notice how many spacers and their order that are on the T/O bearing. One should be a wavy spring washer. Good luck with your project!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 10-30-2010, 06:57 AM
Tule Tom
Hard thing to do by yourself. Have help nearby
Tom
Old 10-30-2010, 09:58 AM
930cab89's Avatar
Thanks for the help, I'll give it a try tomorrow evening.
Old 11-01-2010, 01:19 PM
Easy way to do it.......
Tom
Use two (2) C-clamps and a piece of wooden board to press the spring. Then pick the locking ring out from the groove. I've seen guys just put their weight on the pressure plate and picked the locking ring out. Please take note of the arrangment and set-up of the parts removed. Put them in the same manner or order.
Tony
Old 11-01-2010, 07:22 PM
930cab89's Avatar
Good idea, thanks. I've tried so far to remove it without putting weight on it but that doesn't work.
Old 11-07-2010, 06:09 AM
