What do you look for in used Webers???
I have a 74 2.7 CIS and am working on a winter rebuild. I am considering converting to Webers. What/How do I need to look for to know they are solid.
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
I would say throttle shaft play would be your biggest concern, after that corrosion, and cleanliness.
No left turn un stoned |
RETIRED
Shaft play IS the biggest issue....
Can you explain what throttle shaft play means and what to look for. I also have a 71T with webers so I can play with that a little.
RETIRED
The main moving part is the throttle.....it's connected to the shaft that moves the butterflies. The shaft has bearing and they oval out and cause air leaks when they don't seat right.....
