-   -   CIS - what does this pipe do? (http://forums.pelicanparts.com/porsche-911-technical-forum/574143-cis-what-does-pipe-do.html)
bkreigsr 11-08-2010 07:23 AM
the hose on the left end of this pipe was completely severed when I bought my 85, and the car was running like crap during warm up, and idle. I cut the crimp and replaced with a piece of fuel line and some clamps. Runs like a proper P-car now. Will this be good enough for the long run or does the pipe really need a high-pressure crimped fitting? (pic was lifted from another Pelican for illustration.) thanks Bill K
[see pic pelow]
correction, not CIS, but a Motronic 85 Carrera.
bkreigsr 11-08-2010 07:26 AM
sorry, here's the highlighted pic
http://forums.pelicanparts.com/uploa...1289229979.jpg
Gogar 11-08-2010 08:14 AM
I don't know the answer, but
I would like you to know that the pictured engine is a Motronic engine, not CIS. CiS is 73.5-83.
SmileWavy
bkreigsr 11-08-2010 08:19 AM
I would like you to know that the pictured engine is a Motoronic engine, not CIS. CiS is 73.5-83.
SmileWavy
thanks for the note, I stand corrected. Bill K
bkreigsr 11-09-2010 05:59 AM
any MOTRONICS experts out there today? Bill K
KNS 11-09-2010 06:20 AM
Several people have done the same fix as you have, I have the same problem (and solution you did) on my 84 Carrera.
kodioneill 11-09-2010 07:11 AM
Brake booster vacuum supply line?
bkreigsr 11-09-2010 07:15 AM
that's the type (brake booster) of line it is, but it goes into the bottom of the intake flex elbow with another couple of hose clamps.
PET lists 930 110 328 03 as a "pipeline" -cool- Pelican has it as "fuel line" at $131+/ea.
Bill K
