-   -   Dash Access (http://forums.pelicanparts.com/porsche-911-technical-forum/574531-dash-access.html)
911Gil 11-10-2010 07:51 AM
Dash Access
I'm trying to install an ipod based accessory in the clock hole, the problem I'm facing is running a wire from the clock hole to just behind the center console. I stuck my hand in the hole, but can not find any type of access. Any help will be greatly appreciated!
Best Regards
Gil
Zeke 11-10-2010 08:16 AM
If you stuck your head in the clock hole, you have a small head! :D
The access is really tough. You may have to remove the cover in the trunk and with another person fish wires to where you need them. Of course hooking a wire up back there is impossible. I have seen holes drilled with a long bit thru the cowl so that the back of the radio can be accessed.
You may be able to remove the radio and use a big half circle fishing tool to pull a wire thru the clock hole to the radio. Lots of stuff under the radio on later cars.
pmason 11-10-2010 08:34 AM
Yes, your going to have to go through the trunk, I routed wires through a hole I found up behind the glove box under the dash into the trunk and over to the tach for example.
javadog 11-10-2010 09:04 AM
You don't say what car you have but you may find a hole already punched in the firewall and plugged. Look in the area to the right side of the radio and slightly below. The usual plug is a translucent plastic one. The hole is behind the passenger side air distribution box in the trunk.
JR
911Gil 11-10-2010 10:05 AM
Oops!
I have an 85 911.
javadog 11-10-2010 10:20 AM
In which case, unless your car is heavily optioned, you should have the unused hole I described above.
JR
911Gil 11-10-2010 12:25 PM
I did it!!!!!!!!
Thanks to all for the help!!! The first part was easy (working with the back of the instrument cluster).There are a couple of holes to the right of the radio, I used a long skinny screwdriver some electrical tape, and a three foot piece of twine. I taped the twine to the screwdriver poked thru the hole, then I tied the twine to the wire, pulled on the twine, and wallah (I think thats how it's spelled).
Once again thanks to all for the help!!!!!!!
Regards
Gil
pioneer1 11-10-2010 01:49 PM
I did it
Hey : Good work-no bloody knuckles and "VOILA"SmileWavy (French).
