Stop fronting.
ntrylvl's Avatar
Send a message via AIM to ntrylvl Send a message via Skype™ to ntrylvl
one more (small) fuel leak '73 Coupe
Well, I thought that replacing the fuel sender gasket seal had been the answer to all of my issues with fuel leaks/fumes. Just to be sure, I opened the trunk and watched everything while refueling this afternoon and, sure enough, there is still a small leak at the short hose that connects the filler neck to the fuel tank. Here is a pic (you can see where the gas has leaked out):
I tried tightening the clamp, but that didn't make a difference.
Can I just buy a replacement hose at a regular auto parts store, or is this a special part I need to order? OK, that may seem like a stupid question, but I want to make sure that if I am going to fix the leak, I do it right the first time.
Thanks.
Chris
Chris Harrell
'72 914 1.7 Saturn Yellow, '73 911T-RS Coupe Red
Old 11-09-2010, 09:13 PM
I would think that any correct diameter hose that is designed for gasoline exposure would work.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-10-2010, 08:43 AM
Stop fronting.
ntrylvl's Avatar
Thanks, L.J. That was my assumption, but I thought it would be beneficial to check.
Does anyone know the inside diameter of that section of hose? I'm not near my car at the moment.
Thanks!
Chris
Chris Harrell
Old 11-10-2010, 08:56 AM
Stop fronting.
ntrylvl's Avatar
I ordered the part from our host. I will update this thread if this does NOT solve my problem.
Thanks.
Chris Harrell
Old 11-10-2010, 11:33 AM
AutoBahned
RWebb's Avatar
what are your emissions hoses like? brown or yellow & hard = replacement time with fule vapor rated tubing, NOT regular PVC
Old 11-10-2010, 11:44 AM
Stop fronting.
ntrylvl's Avatar
Actually, those look decent. I know (from reading other related threads) that regular PVC tubes are not up to the task. Thanks for the note!
Chris Harrell
Old 11-10-2010, 07:09 PM
