-   -   Monoball install: How to get trailing arm sleeves out? (http://forums.pelicanparts.com/porsche-911-technical-forum/574976-monoball-install-how-get-trailing-arm-sleeves-out.html)
euro911sc 11-12-2010 09:14 PM
After removing the rubber parts form the trailing arm you have to remove the metal sleeves (2) from each arm before installing the monoball setup.
Ok I heated and I banged and I heated again and I banged harder... <- repeat for 2 hours....
F'n things didn't move at all. I just made lots of dents and marks on the one. So, how did you get them out? :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
-Michael
Chuck Moreland 11-12-2010 09:34 PM
Are you driving into the parting line between the two halves? With a sharp chisel or drift? Lot's of heat?
If all else fails, thread a hacksaw blade through the hole. Saw into the sleeve.
Keep the saw as square as you can. You don't want to cut through into the trailing arm.
You do not have to cut all the way through. If you get about 3/4 through the metal, you will find it far easier to drive out. It will have largely relaxed the tension.
78SCRSMAN 11-12-2010 09:49 PM
The hacksaw method is best. Like Chuck said, remove the blade from the saw and put through hole and re-install blade to saw. It helps if you can secure the arm in a vice.
KTL 11-13-2010 07:31 AM
Heat and driving is what I did and it did take a while & some patience. But I agree the hacksaw blade method is better
euro911sc 11-13-2010 08:48 AM
I used a fair amount of heat and the edge of the parting is now chewed and hammered to a ~45 deg. angle almost all the way around. I even used a bar that has a kind of 2 prong end to grab 2 spots at the same time... nada.
Sounds like a gentle hacksaw will be my new best friend for the afternoon. I would love to put this in a vice, but all the lines are still attached to it. At least I'm not on my back ;)
-Michael
KTL 11-13-2010 09:16 AM
I recall being a bit frustrated on the first one. Second one I kept at it with the heat and drove hard with the punch. But if youre to the point that the sleeve is damaged, time to cut with hacksaw or carbide bit on your Dremel.
euro911sc 11-13-2010 10:36 AM
Maybe I used the wrong tool. I've been using punches/drifts with sharp 90 deg. edges on the tip. that edge would catch the lip easily, but as I hammer on it the lip compresses and I get an nice beveled edge :( I'll see what happens this afternoon.
-Michael
