Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Home of the Whopper
BK911's Avatar
PMO fuel regulator
I am trying to put a set of webers on a 3.0. Stock fuel pump, stock fuel filter (no accumulator), to PMO pressure regulator, back to tank via return.
Can somebody explain how this pressure regulator thing works? It just doesnt make sense to me.
It restricts the return line to maintain your desired supply pressure. What if your pump has too much pressure? How does restricting the return line reduce the supply pressure to the carbs?
If you restrict the return the supply pressure goes up. If it is full open the pressure it still too high. These CIS fuel pumps put out more than the recommended 4 psi. I would think you want the pressure drop BEFORE the supply to the carbs. Am I going crazy?
I checked for return line restrictions. I will check again.
Any ideas?
Thanks,
BK
'62 356B S90 Coupe
'72 914 1.7
'73.5 911T 3.0 Coupe
'78 911SC Targa
'67 Aermacchi/HD Sprint 250SS
Old 11-13-2010, 01:06 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Senior Advisor
James Brown's Avatar
Your not crazy just not an engineer! Say you take the fuel line off the regulator and turn on the fuel pump and let the fuel just flow out (don't do this, just do it in your mind) there will be very little pressure in that hose. Now put your finger on the hose and the pressure goes up. So think of the needle valve in the return line as a finger on the hose. And it's AFTER the carbs so no matter what demand (volume) there is from the carbs, the pressure will always be what you set, like 3.0 PSI.
Carrera 4S
A4 Allroad
Old 11-13-2010, 01:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
zero waste can be done...
Joe Bob's Avatar
Not a good idea to run a CIS or any other FI style pump on carbs. Carbs like about 3-5 psi. "I" would get a rotary fuel pump, put the regulator on the supply side and "consider" blocking the return....
Support your Pelican only Custom Graphic guy
73/83/93 RS Cab, 3.6
www.nbdgraphics.com ** also on FaceBook, there are NO BAD DAYS!
WORLDWIDE SHIPPING AVAILABLE!!!!!
Old 11-13-2010, 01:49 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Senior Advisor
running that (cis, sc pump) on my car and the PMO regulator can handle it (3.2 psi). Ideally, you only need a low pressure pump like the Faucet or the Holley.
Carrera 4S
A4 Allroad
Old 11-13-2010, 01:54 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
deRegistered User
RWebb's Avatar
- this is the opposite of what Richard Parr told me
the Bosch pump is of very high quality and will run a looooong time - just regulate it down with his pressure regulator
When you reduce the vehicle weight, “you get more performance with less of everything.” – Alois Ruf, quoted in THE ESSES (Early 911S Registry Bulletin) Fall 2005, 15(3): 3.
Old 11-13-2010, 02:49 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
CT Cheater
GaryR's Avatar
Send a message via ICQ to GaryR
Me too, and it works perfectly putting out a steady 3PSI from my stock SC pump to my carbs..
Gary R.
PCA National DE Instructor
1978 911 SC Black - PCA Club Racing Stock D
Old 11-13-2010, 02:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Home of the Whopper
BK911's Avatar
Yea, I found a restriction in my fuel line. I took the return right to a can and the pressure was good. No visible restriction so I will go to each connection and see.
Are you SC guys using the stock filter?
'62 356B S90 Coupe
'72 914 1.7
'78 911SC Targa
Old 11-13-2010, 03:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Senior Advisor
you can, I'm not, have 2 filters just before the carbs.
Carrera 4S
A4 Allroad
Old 11-13-2010, 03:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
CT Cheater
GaryR's Avatar
Same here, in-line between the regulator and the carbs.
Gary R.
Old 11-13-2010, 03:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
deRegistered User
RWebb's Avatar
Racor makes a combo filter & water separator that is real nice - I don't have one on (yet).
Old 11-13-2010, 03:55 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
CT Cheater
GaryR's Avatar
Once my car is actually built I was thinking of using the Racor before the regulator and then the two replaceable ones between the reg and the carbs, think that may be overkill?
Gary R.
Old 11-13-2010, 04:36 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
The PMO regulator has 1 in, 1 to carbs,1 return. I would imagine that the restriction is in the in side, not the return side. If it was on the return side that wouldn't make much sense because the high pressure has already passed the carbs.
The problem with what you are thinking is that you are going to be using an 80 PSI pump and restricting it down to 4 at the rear of the car.
That whole line from tank to regulator is going to be filled with 76 PSI at all times. That is not a good idea.
You can get a 3 o 4 PSI pump cheap. I would recommend it.
I use the holley red pump and I think it only puts out about 7 PSI max. To restrict that down to 3.5 is not as dangerous.
Or hard on the pump.
1975 911S Peru Red
Twin plugged, PMO's, 401 Webcams, 11 to 1 JEs, 21/26 suspension, 1 1/4" below euro, on polished 16"s.
"Blind respect for authority is the greatest enemy of truth"
Old 11-13-2010, 04:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
kent olsen's Avatar
Been using a Holley fuel pressure regulator for years in front of my old Webers with no problems, and I don't have a return line either.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
RGRUPPE #104
Old 11-13-2010, 04:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
a by-pass reg restricts the return line to a set psi reading before the restriction. This psi is tapped to feed the carbs. The rest gets dumped into the return line at minimal psi
a dead head reg only restricts and doesn't dump excess. It raises psi before the reg. Pump output psi rises
one member uses a by-pass set to 10 psi and then that 10 psi to feed a dead head set to 4 psi to feed carbs. Gauges before the filter, after the filter where 10 psi is, and a dead head psi gauge of 4 psi enables full monitoring of pump condition, filter condition, and carbs
CIS Bosch is a great pump for carbs
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-13-2010, 05:17 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Shane
snbush67's Avatar
Arrow
Dipso,
What is the pressure is in the same line when it is connected to a CIS system? Is there a difference?
I run, stock filter, then to pressure gauge, then to small filters to each carb.
Shane
Shane -- 78SC Big Port 3.2 SS, 46 PMO Carbs, M&K 2/2, RARLYL8 Headers, DRC GT2-108 Cams, MSD, Clewett Wires, J&E 98mm (Disclaimer-I am a novice and pretend to know just enough to be dangerous (I have the scars to prove it). By reading my post you accept that I am not responsible for any bodily harm, mental anguish, material and/or monetary losses that may result from anything you choose to do based upon my shared experiences.)
Old 11-13-2010, 05:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
ael911's Avatar
Check out my saga with the PMO regulator. Had to build a bypass. As others have said it already, it is just not safe to restrict the line to reduce the pressure. And using the PMO regulator alone, my pressure would only reduce down to about 9 pounds, which is way too high for the carbs...
PMO conversion, it's done...almost
'75 911S Silver Anniversary #164(Formerly JTO's)
Rebuilt 2.7 with full ARP, 9:1 CR.
SSI, GHL, ER polybronze bushings, finned oil lines.
Lowered and corner balanced. CIS retired, now PMOs!
'65 912 slate gray sunroof (driving project)
Old 11-13-2010, 06:57 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
KISS. Start with a 4 psi pump (Airtex or equivalent). 3.5 psi at the carbs, after the filter. No PR needed. Simple.
Sherwood
Old 11-13-2010, 07:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
ael911's Avatar
Your so right Sherwood. But I was too lazy to buy another pump...Haha
FWIW, I have had this system in place for two years now and logged over 15k miles without a single issue...
Andy
Old 11-13-2010, 07:09 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
UNDER CONSTRUCTION!
carrera turbo's Avatar
Im a little confused on where some of you are restricting your fuel lines, i know several of you have had problems with restricting down pressure. but if the return lines are free of restrictions you should have no pressure buildup in the lines or very little maybe 1psi, then you slowly restrict the return to 3psi and the fuel pump is not building anymore pressure then 3psi. so there is not 76 psi of pressure anywhere in the system. if i remove my restrictor from my return line it makes less then 1psi. i would think the cis would last forever under these conditions. so far two years with the PMO system with no problems to date, I understand if the return line gets kinked then the dead head pressure goes to the carbs which is bad.
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 11-13-2010, 07:17 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
Senior Advisor
You are correct Ed, pressure has no chance to build up as it is bypassed. The CSI pump is mostly bypassing
Old 11-13-2010, 07:23 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
