-   -   Turn signal switch (http://forums.pelicanparts.com/porsche-911-technical-forum/575364-turn-signal-switch.html)
70SC 11-15-2010 02:23 PM
Turn signal switch
Hi all, I am SmileWavy having a hard time locating the OEM turn signal switch and was wondering , Are the switches able to be used in more than one model year application , Without cutting & splicing ? Can i change out my switch with another year model switch ? Thanks
HarryD 11-15-2010 03:59 PM
The Pelican Catalog shows this:
http://forums.pelicanparts.com/uploa...1289865531.jpg
You do not show the year of your car, so it is hard to figure out which one(s) would be appropriate.
70SC 11-15-2010 08:03 PM
SmileWavy That's where it gets tricky. The car is a 70 T updated by the PO to a 81 SC . But the turn signal switch currently is the 74-75 model # 911-613-305-00:confused: go figure , That's why i was wondering if certain years cross reference to other years without modification . Could the wrong model year switch account for my high beams not coming on ? My flash works just fine when you pull the stalk back . When you push the stalk forward for high beams , nothing . Thanks
HarryD 11-15-2010 09:07 PM
You may be able to repair your existing switch. Check this thread for some tips: http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html
If I am not mistaken, the Flash to pass function is handled by a different part of the switch then the switch between high and low beams. That my be why your flash to pass still works.
Also, while I am no expert, the difference between the 1970-1973 switch and the 1974-1975 switch MAY be shape of the external stalk. In the earlier cars, it is a U shaped channel and the later cars it is a round shaft. Electrically, they may be identical.
