-   -   83 SC Clutch Configuration (http://forums.pelicanparts.com/porsche-911-technical-forum/575471-83-sc-clutch-configuration.html)
WildMuskrat 11-16-2010 07:15 AM
Good Day everyone,
I am at a dead end with my 2 year Porsche project, a 83SC, new engine and clutch and rebuilt transmission. Did all the clutch adjustments straight out of the book. But when I press the clutch it looks like I am just stretching the cable. I have reviewed many posts on the forum, looked through the internet and watched videos on how this setup is supposed to work. Is the clutch supposed to push or pull the throw-out bearing? Looking at the parts diagram and the linkage set up, the current set up drives the fork towards the front of the transmission not the into the clutch mechanism. I am confused here. I must be missing something. :confused:
Bob Kontak 11-16-2010 08:41 AM
The way you describe it you would be pulling the pressure plate which is correct for an 83.
Here is an article from the tech forum that may help your comfort level. Looks like the old -71 and before- had push type.
Pelican Technical Article: Replacing and Adjusting the 911 Clutch - Page 1
My guess (and only a guess) is that there is something wrong outside of the transmission (omega spring orientation maybe?) that is not allowing the cable to do it's job.
Can you push the clutch pedal to the floor?
psalt 11-16-2010 10:46 AM
If everything is assembled correctly and depressing the pedal does not release the clutch, the first thing I suspect is the pedal shaft roll pin.
Scott R 11-16-2010 11:43 AM
Did you get the throwout arm behind the bearing where it's supposed to be?
Vin-barrett 11-16-2010 11:45 AM
+1
sounds like the arm isnt in the TO bearing
WildMuskrat 11-17-2010 11:56 AM
I have rebuilt the pedal assembly, new pin, in great condition, installed a new cable as well. I noticed in the picture that the fork is on the side of the starter, my is on the opposite side of the power shaft, the drivers side of the transmission. I can push it to the floor, but it does not feel like a clutch>
I will include pictures here shortly, I am looking to drop the engine this weekend and find out what I did wrong. Man, what a bone head move, worked long hours and lots of time to insure things got cleaned, replaced and built right... sheesh the good news is everything is clean and new, so there should not be any issues with getting the engine out.
Flat6pac 11-17-2010 01:00 PM
Now that you have had it together and taking it apart there is a possibility you ruined the fork. You need to measure the fork opening. It should be 75mm and if it reads 80mm, youve ruined it.
When you lower the engine down, you can reach across on the drivers side of the trans with a mirror and flashlight and look into the clutch through the port hole and confirm that the fork isnt in the TOB
Bruce
trojwl 11-17-2010 06:58 PM
I had same problem
My 1982 911SC had the exact same issue. Rebuilt tranny, new clutch assembly, new cable, and, like you say, it's like the cable didn't displace enough length to operate clutch (giving that "cable-stretching" appearance).
Rebuild your pedal cluster. The worn-out aging nylon bushings are worn out and the shaft is contorting. Since clutch pedal and cable bracket are farthest apart in cluster, the twisting really affects cable displacement. Get all the clips, pins, etc. It's a fun afternoon job.
Get the brass set from our sponsor.
I did it and now the clutch works fiine.
http://forums.pelicanparts.com/uploa...1290048760.jpg
WildMuskrat 11-18-2010 06:01 AM
trowjl, thanks for the info, I have rebuilt the pedal cluster new pins and brass. By the way you car looks like mine same color , with sunroof but no tail. By the way what color is this called. I love the look with the black, get lot's of positive comments.
Flat6pac, thanks for the advice, i will definitely be working this thing back together with a fine tooth comb and making sure all components are within specs, any hint of problem and it get's replaced
Bob Kontak 11-18-2010 06:10 AM
Your transmission does not look like this 81 915 regarding the orientation of the shaft and fork? You are saying it is on the other side?
http://forums.pelicanparts.com/uploa...1290089396.jpg
WildMuskrat 11-19-2010 09:58 AM
Yes it is on the opposite side of the starter
LUFTMAN 11-19-2010 10:09 AM
check fork for hairline cracks by the arm area .very hard to see you may have to remove fork and put it in a vise and try to spread arms i have plenty of used forks if you need one. regards tom. good luck
Scott R 11-19-2010 10:14 AM
Your clutch arm is on the correct side for an SC, it's opposite the starter.
Bob Kontak 11-19-2010 12:35 PM
Call me a dunce but I am struggling with the shaft and fork being on the side opposite from the starter. I must be misunderstanding something.
http://forums.pelicanparts.com/uploa...1290198904.jpg
WildMuskrat 11-22-2010 12:55 PM
Folks,
I apologise, I got my bearing mixed up here.
I was looking at the clutch arm assembly only, no paying attention to the fact that I was upside down and coming in from the rear of the car. Sorry for the mix up.
I did get the engine and transmission out , separated and got a good look at my error.
It was the fork not being in the throw out bearing groove as so many have suggested.
I am waiting on a new fork, which looked OK, but I don't want to take a chance.
Thanks for all your help in this, I guess the issue was not realizing it is a pull type clutch, no where in my manual does it mention this, threw me a curve ball and I was in a rush, really stupid things on my part.
Nothing time and good advice won't fix
Scott R 11-22-2010 01:25 PM
Is the fork OK? As mentioned above, make sure it doesn't have any cracks in, or that it's not bent.
Bob Kontak 11-22-2010 06:34 PM
Scott R - He said he is waiting on a new fork in post 15.
Scott R 11-22-2010 07:18 PM
Damn, thanks. Missed that.
WildMuskrat 01-23-2011 02:46 PM
Hey folks,
sorry for the delay, hope everyone had a great holiday season. Installed the new clutch folk, adjusted and Shazamm! it works, got to run it around the block a few times before the weather closed in on us here in Kentucky. appreciate the help. Now on to next 100 items to work on.
SmileWavy
