-   -   Alternator connections (http://forums.pelicanparts.com/porsche-911-technical-forum/575548-alternator-connections.html)
cel 11-16-2010 12:40 PM
82 SC with internal voltage regulator. I searched this forum and the pictures show the regulator cover on bottom with the D- (brown) on the left and B+(red) on the right with 61( blue) on top. My stud for the brown wires is too large for the brown terminals, the red wire terminal fits fine. In other words the brown and red terminals are switched. Has anyone had this problem before?
Bob Kontak 11-16-2010 01:14 PM
Mine looks like this.
http://forums.pelicanparts.com/uploa...1289942036.jpg
cel 11-16-2010 01:18 PM
That is the way mine looks
Bob Kontak 11-16-2010 01:37 PM
That is an 82 alternator in an 81.
304065 11-16-2010 01:48 PM
If you attach the B+ to the D- you will start a huge fire that will probably burn up the car and maybe the building that it's in!
Bob Kontak 11-16-2010 01:56 PM
The red wire post is a fatter diameter stud than the brown wire post. That is probably why the brown wire connector would not fit - 'cause they make it that way so folks will ask good questions like you just did.
