tight as a bull's ass's Avatar
Wheel bearing replacement help!
Hi,
So how does the Grease Cap come off....There is a notch there and I tried prying it off but nothing.
any other ideas? This is the last piece to get access to the Clamping Nut and take everything apart.
Thanks.
Emmanuel
Old 01-22-2002, 08:51 AM
Remember one can use the search function.
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=33754&highlight=grease+cap
I like the muffler clamp method. Jim
Old 01-22-2002, 09:01 AM
chrisp's Avatar
Yeah mine was tough to get off too. I ended up grabbing it with a channel lock and working it loose. The less you rock it the better. Liggle "wiggles" will get it off faster than more dramatic rocking.
Also, I grabbed it from the side, not the front. Basically the Channel lock was in line with the axle, not the direction of car travel if you know what I mean.
It was on there pretty tight. At one point I made sure to double check my jackstands ecuase the car was moving pretty good.
Old 01-22-2002, 09:03 AM
yes, thank you for the link.
The server seems to be slow this morning that's why I didnt do any searches.
EM
Old 01-22-2002, 09:05 AM
Senior Member
Doug Zielke's Avatar
If I recall correctly, good 'ol John Walker recommended using large channel-lock pliers, and twisting it off. That, and a B.F.H. should do the trick.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
age is taking it's toll on doug's memory. mine too aparently. the wife sent me to the store last night for sugar and i brought back milk. a blunt chisel and big hammer gets it off. a couple of wacks on one side, a couple on the other, repeat until it's off. blunt the chisel on the bench grinder so not to scar up the cap, if you care.
206 637 4071
Old 01-22-2002, 10:08 AM
Senior Member
Originally posted by john walker's workshop
age is taking it's toll on doug's memory.......
Ouch! The truth hurts, John.
Actually it's a combination of age.....and 'other' things.
(And don't let that car fall on your FLSTN!)
Old 01-22-2002, 10:22 AM
Here's a couple ideas:
Or, modify the cap and do it turbo style:
Old 01-22-2002, 10:24 AM
HALLELUYAH!
Thank you John Walker....you're chisel and hammer did the trick! It took about 40 seconds.
I think I'm deaf now from all the noise but it popped right off.
ok, clamping nut and washer are off...now do I just pull off outer bearing?
Old 01-22-2002, 10:29 AM
