shinrai's Avatar
Is this the correct clutch kit? '87 911 3.2
Doing an engine refresh and ordered a new clutch kit. 'Was supposed to receive a rubber centered disk but received a spring centered one instead (FWIW I don't really care if it's spring or rubber).
1. Is this the correct disk and kit?
2. How do I tell if the pressure plate is correct because it appears to be exactly the same as the old one but the numbers on it don't seem to be the same.
and here is a pic of nearly 3 weeks of cleaning, sweating and cursing. It should be going in later this week.
(I'll post more details when I've completed this job)
'87 911 GP White "casper"
'79 930 Copper Brown Metallic "beast"
'93 968 Amazon Green Met "moby"
'97 Esprit V8 "flat eric"
'97 993 Speed Yellow "tbd"
Old 11-16-2010, 08:39 PM
shinrai's Avatar
Somebody must've done a G50 clutch job with a sachs spring centered disc recently. Has anybody ever seen a 4 spring disc on a G50? I thought they were all 6 spring. Any thoughts are greatly appreciated.
TIA
Installed fuel and ignition systems today.....tomorrow new flywheel and clutch (hopefully)
Cheers!
Old 11-17-2010, 05:38 PM
