I'm a loser, baby.
oregonmon's Avatar
Is $250 a good price for anew windshield?
I think he said the aftermarket glass brand was (sp?) Pilkinson with gasket installed for $250.
OEM was $280.
Thoughts.
Old 11-11-2010, 07:49 PM
Certified Pre-Owned
BGCarrera32's Avatar
That would be "Pilkington" and $250 is fair.
OEM was Sekurit (if you are talking about a 911) and they are more like $1k from the dealer.
'84 Carrera Coupe
Old 11-11-2010, 07:56 PM
Just curious --- Sekurits are still available??? Even for 'almost' vintage cars like say an 83 SC?
Old 11-11-2010, 08:57 PM
skinnerd's Avatar
I'd have to agree
$250 is dirt cheap for a good windshield for a 911.
$1000 sounds about right from the dealer.
I would think PPG would make some good reasonably priced windshields for Porsches as well.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 11-12-2010, 04:35 AM
No matter which glass you decide on do not go with anything but a Porsche seal, it is the only one that will seal and look correct in the corners.
Just my $.02
Regards
Old 11-12-2010, 04:42 AM
ahead of the curve
Jeff Burger's Avatar
depends on the year of the car - sounds like an earlier one pre964 without the radio antenna in the windshield ?
Old 11-12-2010, 06:18 AM
Mitch Leland's Avatar
I had a tinted W/S with a blue shade installed by Glass America for $247.00. I furnished a new Porsche gasket. BTW as previously discussed, I wouldn't use an after market gasket because the upper corners do not have adequate coverage. I knew the installer and he did a superb job.
For that kind of money it really doesn't make much difference who's W/S you're using. Sooner or later they'll all get pitted anyway...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 11-12-2010, 07:26 AM
IROC's Avatar
They do. I have a PPG windshield in mine. ~$225 installed and I supplied the gasket.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-12-2010, 07:43 AM
Certified Pre-Owned
Maybe not...but back in '06 or '07 when I inquired about one they were available at my dealer for around $950.
They could not get the rear glass for me.
'84 Carrera Coupe
Old 11-12-2010, 09:25 AM
Goldfinger
Mattcamp's Avatar
That's a good deal but make sure that you buy a german seal from our host. The aftermarket seals are JUNK!
1984-Carrera (pewter metallic)
Old 11-12-2010, 09:47 AM
rgrimm's Avatar
I supplied the gasket and had a PPG installed for $200 two years ago...so you're right in the ballpark.
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 11-12-2010, 10:13 PM
Tilikum Turbo's Avatar
Any one else notice how distorted the NEW glass looks in the new 911's...there's so much distortion, it comes off like it was made for a 1975 Ford...
And I remember a technical series Porsche used to put in car mags showing things like a grid they put behind the windshield as a quality check against bad glass. I suppose the 75K+ you now pay for a 911 just isn't enough money to do the job right!
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 11-12-2010, 11:10 PM
I'm a loser, baby.
oregonmon's Avatar
Thanks for all the replies guys. I'm not sure about the gasket so I will check on that.
Thanks again.
Old 11-13-2010, 07:26 AM
I'm a loser, baby.
oregonmon's Avatar
Oh BTW comes with a lifetime warranty against defect and leaks, for as long as I own the vehicle.
Old 11-13-2010, 07:27 AM
darthracing's Avatar
Send a message via Yahoo to darthracing
That's a steal - $1200 for my replacement oem...
Old 11-13-2010, 07:53 AM
I agree that in general.....US manufacturers of US cars show much less glass distortion than (say) Euro cars that had Euro safety glass in mind to be used for the home market ( breaks into small pieces)...vs....those same Euro cars using US-spec safety glass for the US market ( laminated safety glass).
Another area of Weideking-inspired cost cutting, it seems, just like the *awful* orange-peel on post 996 car's paint compared to earlier air-cooled cars.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-13-2010, 08:05 AM
PPG is now called PGW, PGW Auto Glass
I had a PGW windshield installed in April, it was $205 for the glass. I got a OE seal from our host and it was even a bit short in the passenger side upper corner.
Tom
'82 911 SC Non-sunroof Coupe GP White/Black
Old 11-13-2010, 09:40 PM
If one uses a factory seal and STILL has problems getting the corners to fit....look at what Randy Blaylock says here.... brilliant---> Gap between Rubber Windshield Seal & Body
Wil Ferch
Old 11-14-2010, 03:24 PM
scarceller's Avatar
I just sourced a PPG new windshield for my 84 Carrera locally in RI for $150.00 no install, just pickup the glass and install myself.
I agree that you should use the factory OEM seal. I'm going to use the 964 seal (also used on some 89 Carrera cars). I've heard mixed results on this. The 964 seal is all rubber with no metal trim and I like this look better. I also have a spare carrera seal with metal trim if I need it.
I'll be sure to post my results on how this install goes, should get to the install within the next 2 weeks.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-16-2010, 01:56 PM
Techne's Avatar
Sorry, meant to post earlier. My PO did a Pilkington windshield through Marque Motors in '04 - cost $440 for the glass + $98 for the OEM seal.
25K miles later it still looks good, so you should be fine with the Pilkington, mon.
1984 911 Carrera
Old 11-16-2010, 08:01 PM
