-   -   Looking for help identify elec conn in front compartment (http://forums.pelicanparts.com/porsche-911-technical-forum/575871-looking-help-identify-elec-conn-front-compartment.html)
lr172 11-18-2010 09:56 AM
I am troubleshooting some blower problems and found some interesting wiring problems in the front compartment.
My courtesy light doesn't work there and I had some un-connected connectors. I explored this last night to rectify. The hood was off for painting by the previous owner.
The wires for the light are BK & BR/WH with a female connector. I found another male connector with the same combination, however it was plugged into something else which I now believe was a mistake by the painter. It would seem logical that the matching color / gauge pair (1 male and one female) would go together. However, that leaves me not knowing how to match up the other connections. Here is what I have:
Male - BR/WH & BK - Thin gauge
Female - BR/WH & BK - Thin gauge - Origin courtesy light
Female - BR & BK - Thick gauge
Male - BK/GR & BR - Thin gauge
Male - RD/WHI & BR - Thick gauge
All of the connectors are of the same style and they are all bunched together in the same area (near hood hinge on right side). I am assuming the like pairs go together for the courtesy light, but not sure which Male should go with the open female or if they are all unused options. I couldn't find any help in the Bentley manual.
This is an 88 911. Thanks for any assistance you can offer.
Larry
Joe Bob 11-18-2010 11:03 AM
You can download the PET.
Porsche Classic Original Parts Catalogue - Classic Genuine Parts & Literature - Porsche Classic - Dr. Ing. h.c. F. Porsche AG
86 911 Targa 11-18-2010 12:21 PM
Larry
Larry,
If PET doesn't work out, here's a page from our "well loved" '86 factory manual.
It should be compatible with your '88.
Good luck,
Gerry
http://forums.pelicanparts.com/uploa...1290111670.jpg
lr172 11-18-2010 12:44 PM
Thanks for posting that dia; It helps. I went and followed the wire with the female connector and it goes to the windshield washer outlet on that side, so it must be a spare, as I don't have heated washers that I know of. That leaves two males without females, so I will assume for now they are harness connectors for things I don't have.
Thanks for your assistance. I appreciate it.
Larry
warner53 11-18-2010 12:44 PM
I LOOKED AND FOUND THIS ON MY 86 TARGA
THESE TWO GO TOGETHER FOR THE TRUNK LIGHT
Female - BR & BK - Thick gauge NOTHING CONNECTED TO THIS ONE
THESE TWO GO TOGETHER BUT I CANNOT TELL WHERE THEY GO
warner53 11-18-2010 12:48 PM
OOPS i GOT IT WRONG
CORRECT
Male - BK/GR & BR - Thin gauge NOTHING CONNECTED HERE
THESE GO TOGETHER BUT i HAVE NO IDEA WHERE TO.
GLTY
86 911 Targa 11-18-2010 12:56 PM
Larry
Larry,
Not so sure about the heated washers.
Here's a copy of our window sticker.
http://forums.pelicanparts.com/uploa...1290113776.jpg
86 911 Targa 11-18-2010 01:12 PM
Wires.
Larry,
You have brought up an interesting issue.
If our Owner's Manual is correct, the windshield
washer line heating is temperature dependent.
However, I cannot find anything in my factory manual
that senses the ambient temperature.
Let's hope that someone chimes in on this one.
Gerry
http://forums.pelicanparts.com/uploa...1290114727.jpg
lr172 11-18-2010 01:29 PM
Thanks for looking. On your car, was one a male and one a female. If not, how were they connected
Thanks again for your help.
Larry
warner53 11-18-2010 01:37 PM
OOPS i GOT IT WRONG
CORRECT
GLTY
Warner
lr172 11-18-2010 02:51 PM
Thanks for all of your assistance here. I appreciate it.
86 911 Targa 11-18-2010 03:42 PM
Wiring
Here you go.
http://forums.pelicanparts.com/uploa...1290123734.jpg
steely 11-18-2010 05:14 PM
just in case this helps....
http://forums.pelicanparts.com/porsche-911-technical-forum/544969-trunk-light-power-connector-ident.html
