Will 915/02 trans work with 76' mag case?
Anyone know if there is a problem using a 1973 915/02 transaxle with my 1976 magnesium case engine?
Old 11-21-2010, 05:10 AM
AutoBahned
RWebb's Avatar
there a lots of minor problems with the early 915s - it will work, but is harder to fix
do a search & replace the shift shaft seal, add a groove & dam seal & whatever else you find, NOW... BEFORE you install it
assume your car already has the mechanical speedo drive (?)
Old 11-21-2010, 12:43 PM
