-   -   Temp. sensor help. (http://forums.pelicanparts.com/porsche-911-technical-forum/575915-temp-sensor-help.html)
bklyn 11-18-2010 02:21 PM
Temp. sensor help.
I found I still have the one wire sensor so I decided to switch it out. My new sensor arrived today and I would like to go it this weekend. Ok I found the tech article and know its the first connection on the bracket, the tech. says to remove the rear wheel but I still cannot see its routing, what else am I missing before I dig in?:)
theiceman 11-18-2010 02:35 PM
remove the OTHER rear wheel ? :)
JerP 11-18-2010 03:18 PM
Lenny the process is really quite easy. There is some good information if you search the different threads. This is a link to a tech article detailing the repair: Pelican Technical Article: Cylinder Head Temperature Sensor - Upgrade for 84-89 Carrera
JerP 11-18-2010 03:22 PM
Here is another thread that may help:
http://forums.pelicanparts.com/porsche-911-technical-forum/6578-head-temperature-sensor-replacement.html
bklyn 11-18-2010 03:24 PM
Thanks Jeremy that was what I was looking for!
bklyn 11-18-2010 03:32 PM
What a great write up with good pictures, now I got the picture and it makes sense.
steely 11-21-2010 12:20 PM
Lenny - can you post the CHT PN? I ran 964.606.405.00 and 930.606.915.00 but neither turn up in the catalog - and the ones that do show aren't for my 87.
Thanks,
Dan
