Certified User
billjam's Avatar
This what I ended up with and it has been working OK for a few years now.
There are probably other combinations of parts that will work, but I was guided by the parts I had available or could make at home.
Your question was regarding which starter. As long as you position the ring gear in the correct place, the original Bosch unit will work or its HiTorque equivalent.
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 09-12-2018, 03:15 PM
hda hda is offline
Thanks Bill - this helps!
Old 09-21-2018, 11:27 AM
hda hda is offline
I am guessing you made those spacers yourself?
Maybe a stupid question but why make 2+5mm and not a 7mm in total?
Old 09-21-2018, 11:53 AM
I assume because a 7mm spacer would not achieve the same effect. The spacers, as illustrated, are providing spacing for multiple components. If a 7mm spacer were used, certain planes would be altered.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 09-21-2018, 01:56 PM
Certified User
billjam's Avatar
Exactly.
The 5mm spacer sets the correct position of the pressure plate in relation to the flywheel.
The 2mm spacer and the inner ring gear are used to set the correct position of the outer ring gear in relation to the starter pinion.
Bill
Old 09-22-2018, 01:05 AM
