How can one tell if a 911 is factory widebody or been converted?
I have a 77 911 and I purchased it as a widebody, the fenders blend in so perfectly to the rest of the car that I wonder if it is a factory widebody or converted? (non-turbo) Thanks.
One of the option codes should be 491, I believe, for the turbo look. The brakes should be the turbo version and some other stuff, too. I don't know all the goodies for this option, though.
The point is likely moot, as in 1977, I don't believe the turbo look option was available. |
The Turbo Look option was only offered on 3.2 Carreras from '84 to '89.
The easy way to tell a factory one from a conversion is the brakes. The factory M491 optioned cars will have a larger caliper mounted behind the rear axle center as shown in the bottom picture. The standard narrow body 911s had the caliper mounted ahead of the rear axle center. The rear brakes are in a different position because the factory M491 cars all have 930 trailing arms. The 930 trailing arms required different pick-up points on the tub, so they can't just be bolted on to a narrow body tub. http://forums.pelicanparts.com/uploa...1290379185.jpg |
Even on a Carrera 84 to 86, the sure tell is the rear torque tube. The tube at the trans mount will have location for the bolts of a 915 and for the turbo trans about 30mm apart. The next item is a Turbo look had black Porsche shocks and struts and does not have turbo tierods.
Bruce |
Sounds like you got some good body work from the PO.
Scott |
| All times are GMT -8. The time now is 05:27 AM. |
