VMAX1's Avatar
What is a good multimeter
I need to buy a multimeter and there are a bunch of different types out there. Need one to work on the Carrera. What brand do you pro's suggest getting?
Old 11-29-2010, 12:50 PM
al lkosmal's Avatar
Fluke has always made a very nice multimeter.
Regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 11-29-2010, 12:52 PM
Happiest when Tinkering
gsmith660's Avatar
Originally Posted by al lkosmal View Post
fluke has always made a very nice multimeter.
Regards,
al
+1
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-29-2010, 12:57 PM
Hi
Targa Me's Avatar
+2 on the Fluke.
Actually almost any MM that reads true RMS should do well for you. MM's that read true rms tend to be a little better than the others.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 11-29-2010, 01:04 PM
Platinum Member
dad911's Avatar
Fluke may be the best.....
but you probably don't need that precision. Buy a cheaper one, and you won't be upset if you blow it up by trying to measure resistance on a live circuit or set the meter to amps instead of volts.
Sears has a decent meter often on sale.
I also use test lights for most troubleshooting instead of reaching for the meter first.
Old 11-29-2010, 01:10 PM
tharbert's Avatar
The Fluke 77 and 177 multimeters are great. They are also upwards of $250.
The inexpensive multimeters at Radio shack will do everything a novice electrical gremlin hunter needs. Volt, ohm meter and circut tester will be the most used functions. Most all have those. Just don't throw away the user's manual!
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-29-2010, 01:11 PM
wwest's Avatar
Hate to say it, admit it, but Radio Shack has a rather good one for under $50.
Includes amp connection failsafe warning and frequency measurement.
Fluke has a good name, reputation, but fewer functions and more expensive.
My professional tool kit includes a Fluke but my garage has the Radio Shack.
Old 11-29-2010, 01:22 PM
kodioneill's Avatar
Lowes has a Greenlee Meter for a reasonable price. Around $35.00 it's a nice middle of the road meter.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-29-2010, 01:23 PM
irl irl is online now
irl's Avatar
Send a message via AIM to irl
This is one of the coolest products I've seen for many of these needs. No affiliation but its been on my list.
PP319FTC Power Probe III ....“Powers up Components!”
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 11-29-2010, 01:46 PM
AutoBahned
RWebb's Avatar
or buy a used Fluke or other quality one
what you want is one that has a nice rubbery case around it so you can bounce it off the concrete floor and still use it
Old 11-29-2010, 01:51 PM
Jack
Every lab I have been to (been in a bunch all over the World - literally everywhere but Africa and Antarctica) has a Fluke in it....
Now the question is, on a car, do you really need the precision (vs. accuracy) that a Fluke will provide, they do cost more.
I my garage, I use a cheap-o radio crack multimeter.
-Jack
85 Carrera Cab
Old 11-29-2010, 03:16 PM
HarryD's Avatar
IMHO, all you really need is the cheap Harbor Freight meter for your needs.
This has all the functionality you need: 7 Function Digital Multimeter
Typically on sale for under $4.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-29-2010, 03:20 PM
AutoBahned
RWebb's Avatar
buy 2 - when you drop one, grab the other one
in the spirit of full, I have a Fluke, a Beckmann, a Radio Shack, an even cheaper no-name one, a 4.5 digit Tek and probably some other stuff floating around somewhere
an analog, needle based thing can be handy too, esp. for O2 sensor testing
Old 11-29-2010, 03:38 PM
Recreational User
porschenut's Avatar
I got a great Craftsman one from Sears that was about $80 and I love it. It's paid for itself about 25 times I figure.
Old 11-29-2010, 03:47 PM
Less brakes, more gas!
euro911sc's Avatar
I had a cheapo Shack meter. Lasted about 8 months... then it started registering the incorrect voltages. I knew this as I borrowed a fluke from work after getting odd readings. I did not screw up measuring in the chepo unit or blow it up or anything like that. so I got a nice rubber covered unit used off craigs list. Its great.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-29-2010, 03:50 PM
+1 with HarryD's HF special. I have a Fluke as well as the red one from HF (a gift). It does the job; not sure about it's longevity, not as convenient to read as the autoranging fluke; probably not as robust, as accurate or can measure as much. The Fluke can also measure temperature wih an optional thermocouple; other accessories as well. Keep one in the trunk for roadside repairs/diagnosis. Will ultimately tell you more about a circuit than a test light. The HF version might provide you with variable service depending on when/who put it together or how many times you drop it or switch it ON or OFF. On newer vehicles with computer controls, make sure the meter's internal resistance is high.
Sherwood
Old 11-29-2010, 03:54 PM
David's Avatar
Fluke.
I found if you work for a large company they probably get a good discount at Grainger. Flash your company ID for a 10 to 20% discount.
Old 11-29-2010, 04:04 PM
Get one that is fused internally and has a rubber surround on the case. Using it around the house or garage the batteries will fail and ruin it before you wear it out. The greenlee one I have used, not bad for the money.
Old 11-29-2010, 04:26 PM
In maintenance phase
daniel911T's Avatar
Flukes kick ass. I used them to work on submarine sonar gear in the Navy. They are also pretty expensive.
That said, around the house I have an Acutron, which I think I got from a NAPA. It has a temp probe, all the normal ranges, and has a tachometer attachment.
I like it.
Harbor Freight's nicest one will also do great for you and will be cheap. I would strongly suggest you go the HF route. Like Randy said, buy two, or three.
Dan
Old 11-29-2010, 04:35 PM
RETIRED
Joe Bob's Avatar
Fluke...eBay special....got 2.
2012 ML350 3.0 Turbo Diesel
Old 11-29-2010, 05:24 PM
