sda sda is offline
lightest 911 is ? and the final 150 lbs
My car weighs 1975 .. 911 chassis 74 body . I'm looking to loose another 100 lbs
I can't see where ??
Old 11-23-2010, 02:46 PM
RETIRED
Joe Bob's Avatar
Either list what you HAVE done or this turns into 220 suggestions....
2012 ML350 3.0 Turbo Diesel
Old 11-23-2010, 03:03 PM
Band.
How much do YOU weigh?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 11-23-2010, 03:06 PM
sda sda is offline
last 150#
what's left ? rear metal carrera flares . otherwise f/g front lid ,fenders ,c/f roof , wing . rear seat metal out , holes drilled where possible , all windows lexan
fikse wheels
Am i overlooking something heavy worth doing ?
Old 11-23-2010, 03:10 PM
Grappler
Rodsrsr's Avatar
Thats pretty light... I have done the same mods you mentioned and mine comes in at 2200 I would be happy if I were you.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 11-23-2010, 03:39 PM
Alter Ego Racing
ErVikingo's Avatar
Undercoating and all unused tabs and brackets. Approx 50-65#'s
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 11-23-2010, 03:43 PM
AutoBahned
RWebb's Avatar
put really narrow wheels on it - they are lighter
Old 11-23-2010, 04:01 PM
AlfonsoR's Avatar
GT2 brake rotors and binders, titanium exhaust, braille battery, rain gutter delete
Old 11-23-2010, 04:07 PM
+1
you don't specify if this is a racecar or streetcar. racecar I assume. the last 100lbs is the hardest to drop.
acid dip the chassis.
remove all unused brackets as mentioned.
remove unnecessary cage bars and replace with thinner gauge or delete altogether.
ceramic brakes (not legal in your race class?)
lighter wheels/tires.
single lightweight race seat.
delete the dash.
delete the bumpers and use covers only.
etc etc. you have to be creative and willing to spend $
2002 Porsche 911 turbo
2007 Porsche Cayman S track car
1987 Porsche 924 Carrera GT tribute
2015 BMW X5
Old 11-23-2010, 04:27 PM
Navin Johnson
TimT's Avatar
I'll just call it 1850# wet :-)
'69 911 GT-5
'75 914 GT-3
and others
Old 11-23-2010, 05:37 PM
Navin Johnson
TimT's Avatar
This does become significant...
I went from a beefy 220# down to 180#... and then drifted back up to around 192#
I like to eat.. If I can maintain 185# I and my Doctor would be happy...
'69 911 GT-5
'75 914 GT-3
and others
Old 11-23-2010, 05:43 PM
petevb's Avatar
You might crib from here:
AUTO PATUTSCHNICK
Empty weight near 1750 lbs with a 6 speed, GT3 brakes, 964 based motor, big wheels and tires, cage.
That means with mag case motor and trans, S brakes and smaller wheels/ tires it'd be very light, likely sub 1600. How far do you want to go?
Ceramic brakes are similar in weight to 930 brakes, fyi, maybe a pound or two lighter overall.
Old 11-23-2010, 06:31 PM
Mahler9th's Avatar
Well...
depending on what is done already, lots of opportunities or few or somewhere in between. Be careful of deceptive advertising practices. For example, I cut out my rear seat for serviceability. Weighed a whopping 6 pounds. Aluminum panels weight about 3-4 pounds. Also note that scales can sometimes be off.
My car weighed around 1950 with oil and fuel but no driver last time I corner balanced. I recently made simple carbon fiber/led tailights for about $40, so now I will lose another 2-4 pounds of rear weight (versus 993 stock taillights). Then I will make a carbon fiber frame for the polycarbonate rear window... that will save me another 1-3 pounds as I will no longer need the rubber gasket/seal. And the project will keep me away from those provocative Pelican Parts BB Off Topic picture threads... well maybe not.
Brake rotors and rotors/hats can be heavy... mine are really light. I like the idea of a carbon fiber tailbase... I'd do that instead of fiberglass on a fresh build if I could get the money right. I like the idea of a light Voltphreaks battery if the money is right.
I am curious about the 1850 pound example here... details on that would be interesting.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 11-23-2010, 06:48 PM
haycait911's Avatar
f/glass doors? I'm at about 1975 lbs and glass doors are the only big thing left. but for a street car I wouldn't/won't do it.
Old 11-23-2010, 06:57 PM
abit off center
cgarr's Avatar
I don't see you said anything about the doors??
______________________
Craig
G2Performance
Navin Johnson
TimT's Avatar
Details... nothing secret or out of the realm for a person who wants to have a light car in the end
69 tub, long wheel base...
Tub is stripped .. roof cut off
Fenders are cut off...
All above replaced with carbon/kevlar/or glass
All windows are plastic..
etc...
BTW my car still has steel trailing arms, I bet I lose 5 more pounds when I swap them for alum
'69 911 GT-5
'75 914 GT-3
and others
Old 11-23-2010, 06:58 PM
