Where does this wire go to?
Hi- I hate to be a pain while waiting for my Bentley to arrive, but I opened up My Steering column to fix the headlight/turn signal switch, and found a loose wire. I can't figure out where it should go. I traced it around to, I think, the washer/wiper stalk, but I have cruise control, so it just might go to that.
Anyone have any ideas where it should go?http://forums.pelicanparts.com/ultimate/confused.gif
Jason S.
Bethesda, MD
1982 911 SC Targa
2003 Mini Cooper S
Old 01-08-2011, 11:59 AM
sudo apt-get purge 930
equality72521's Avatar
Ground for the horn
--clutch-monkey
Old 01-08-2011, 12:01 PM
Then I just use one of the screws holding the plastic covers on? Or is there a specific mounting spot for the ground?
Jason S.
Bethesda, MD
1982 911 SC Targa
2003 Mini Cooper S
Old 01-08-2011, 12:09 PM
Should have connector on the back of the steering wheel
--clutch-monkey
Old 01-08-2011, 12:12 PM
Poor-sche Lover's Avatar
Yes, it is a ground for the horn. That wire simply connects where you thought, on one of the bottom screws that are holding the housing on. The connector on the back of the steering wheel only connects the actual horn button to the trim ring that contacts the bent metal piece at the top of your picture.
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 01-08-2011, 12:18 PM
