SC Ray
81 SC Ray's Avatar
Is platinum OK??
Hi,
I discovered that the previous owner put Bosch Platinum spark plugs in my stock 1981 SC. The manual calls for standard copper plugs. Is there any problem with using the platinum plug??
Thanks.
Ray
Old 11-28-2010, 04:30 AM
UnRegistered User
billybek's Avatar
My SC came with those in it as well.
Changed out to Bosch copper plugs and it ran better.
Bill K.
Old 11-28-2010, 05:36 AM
If those are the 4-ground Electrode type, they suck.
NGK or Bosch solid copper is conventional wisdom.
Old 11-28-2010, 06:18 AM
SC Ray
81 SC Ray's Avatar
They are not the four ground type - they have the single electrode.
Old 11-28-2010, 06:27 AM
Band.
+1 If you have them out and you're looking at them, then spend $10 and put in some Bosch or NGK copper plugs. I think the Bosch is WR5DC and NGK is BP7ES
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 11-28-2010, 07:13 AM
Information Junky
island911's Avatar
I think that the platinum's are designed more for longevity (while using as little of the expensive electrode material as possible) whereas the old-school type of plug give a bigger better spark, but need to be re-gapped/replaced more often.
Old 11-28-2010, 10:00 AM
SC Ray
81 SC Ray's Avatar
I have new correct plugs, I just could not get to plug number 6. I got the tool on it, I just could not get enough leverage with all the other stuff in the way. I have to get creative!! Like everything with the 911 - you have to be patient and learn to do a lot by feel!!!
Old 11-28-2010, 10:16 AM
Under the radar
Trackrash's Avatar
What Bosh platinum? They make four types of "platinum".
My experience is with "platinum plus", the type that has the one tapered thin electrode. They suck and should not be used in an aircooled motor. The tip runs hot and encourages pre-ignition.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-28-2010, 10:20 AM
FYI: a couple people in this old thread thought iridium was good.
No first hand experience myself.
iridium spark plugs
Old 11-28-2010, 11:00 AM
SC Ray
81 SC Ray's Avatar
Gordon,
That is what I had --- I say had --- I just changed all the plugs to the factory recommended Bosch plugs. I have no idea why the previous owner, or his mechanic would put those plugs in.
Thanks for your help.
Ray
Old 11-28-2010, 02:34 PM
