-   -   Rear bleed nipples different size from front? (http://forums.pelicanparts.com/porsche-911-technical-forum/577566-rear-bleed-nipples-different-size-front.html)
dave 911 11-28-2010 03:10 PM
Do all 911's have different size bleed nipples on the rear and the front? I did a search and couldn't find anything....
I've got my system all put back together after replacing the brake lines and rebuilding the front calipers, and notice (to my dismay, as I don't have a small enough wrench) that the rears are smaller than the fronts. 9mm on front, looks like 7mm on the rears?
Always looking for a good excuse to buy more tools :).
Is this the stock set-up? If so, why?
tia
James Brown 11-28-2010 03:20 PM
Sometimes replacement bleeders are different size but the hole is the same, Get some speed bleeders and the will be all the same.
Bob Kontak 11-28-2010 03:22 PM
Yes - I believe the rears are 7mm. Just did mine two weeks ago.
Daytona 11-28-2010 03:44 PM
On mine they are all 9mm and the line size is 11mm. 911 get it!
