83 SC Speakers
I just removed the left front and left rear speakers on my 83 SC.
It is pretty clear that the fronts are 5-1/4s Blaupunkts. The rears are Blaupunkt DL 1525 1A. These measure to be 4 X 6s max on the longest and wides part of the speaker. I did not measure the widest/longest part of the grill. Which measurement is the correct one?
I'm a bit confused because Crutchfield indicates that the stock speaker for the 83 SC rear is 5X7. However, based on my measurement, it seems to be 4 X 6s tops.
Does anyone have experience on this?
I'd like to replace with new speakers soon. Just want to make sure I buy the right sized speakers.
Thanks!
Old 11-27-2010, 07:26 PM
FrinkFrog's Avatar
Send a message via AIM to FrinkFrog
4x6. That's what I used to replace the big ugly Alpine/Rockford Fosgate (with plywood spacer) the PO had installed. You might be able to use larger speakers, but the shelf depth is the problem.
'83SC
'76 911S - Sold.
Old 11-27-2010, 09:56 PM
Thanks. What speakets
Did you use in the back?
Old 11-27-2010, 10:28 PM
a nice setup is 6.5 fronts w/2x75 amp
you probably won't want rear after that
member bell has a good act for setting up the rears that's a better routine than a stock install
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-27-2010, 11:35 PM
2002 996 C4S
jcsjcs's Avatar
Do the 6.5 fronts fit in the stock setup?
And do you have a link to the "bell setup"?
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 11-28-2010, 05:57 AM
Fleabit peanut monkey
Bob Kontak's Avatar
See this post. There is some good information and I particularly like the links in post #12 regarding the infinity speakers.
Audio experts - village idiot needs help
Old 11-28-2010, 06:18 AM
the door sheet metal has to be trimmed
bell replied in Bob Kontak thread that he listed above
send him a PM and e-mail
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2010, 08:36 AM
FrinkFrog's Avatar
To answer the question posed to me: I hated the big speakers in back, so I simply bought a pair of 4x6 Pioneer coaxials and left the fronts alone... I don't even know what they are. But I just ordered a Blaupunkt HU with digital interface (no more CD's!) and post #12 (above link) has really got me thinking I could get better speakers and do away with the power amps the PO had installed into the car. To be honest, I don't have the music on very often while driving the car (why I haven't been gung-ho on changing things)... but getting rid of the amps and saving weight... that's intriguing.
'83SC
'76 911S - Sold.
Old 11-28-2010, 08:53 AM
some say back is for fill only
besides.. a nice muffler sounds better back there for fill
I need the 75 amp to prevent clipping and get as much bass as possible. When I'm doing speed limit the audio helps. At speed the engine and V-1 sounds better and is necessary.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2010, 09:50 AM
Thanks all for contributing your ideas and the links!
I am going to try piecemeal impreovements.
Right now the stock spkrs and the 20 yr old Jensen head unit with a tape deck sounds utterly crappy.
I am planning on swapping out front speakers first, see how that goes. If need be, then the rear spkrs. Then, head unit. Then if still needed and i am ambitious, an amp and a sub. I like those self contained subs --- like the Blaupunkt 'drum/barrel' looking ones--- just leave it on the floor of the back seats.
Old 11-28-2010, 10:12 AM
I have crossovers at around 120hz for the woofer part of the 6.5 as then I can still get volume without the possibility of damage and 120hz is plenty good in these noisy cars
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2010, 01:14 PM
nineball's Avatar
no it doesn't. the door panel opening must be opened up but the sheetmetal needs no modification. you might need a small spacer depending on the mounting depth of the speaker.
what do you mean exactly about 120hz being good in these noisy cars? i don't understand what the crossover point has to do with the car's inherent noise.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-28-2010, 10:23 PM
does door panel opening tin sound better than sheetmetal?
The 6.5" above 120hz delivers enough bass in these noisy cars so you can turn up the volume further at that setting than if the crossover was at 60hz where it would distort at same volume. Test it for yourself.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2010, 10:41 PM
nineball's Avatar
what are you talking about? i really don't understand that first statement.
the crossover point only determines what frequencies the speaker can output. if the speaker can handle playing down to 60hz there will be no distortion providing you feeding it a clean signal. my 6.5 can easily play below 60hz with 100+ rms being fed to them.
Old 11-29-2010, 06:32 AM
Just installed new speakers....
New speakers in an 83 SC
Old 12-01-2010, 12:38 AM
The crossover determines what frequencies the speaker is asked to output, not what it is actually capable of.
The level of distortion is very much a function of the SPL (sound pressure level) that the speaker is asked to output at a certain frequency. So a 120Hz cutoff point will allow the speaker to have a lower overall distortion as it is not asked to produce low frequencies at a high SPL (something that requires larger cone motion => distortion).
I think what RoninLB means is that if you filter out sound below 120 Hz, which is drowned by the noise anyway, you can enjoy everything above 120 Hz louder than you otherwise could.
1980, 911 SC. Ex-US car in Sweden since June 2010. Insta: @911scowner
Old 12-01-2010, 08:02 AM
