-   -   handling problem (http://forums.pelicanparts.com/porsche-911-technical-forum/578700-handling-problem.html)
Augustus 12-05-2010 10:47 AM
handling problem
'95 993 c2
When driving on the freeway on a long right hand turn doing 75mph I came upon traffic and slowed down. When I lifted off the throttle the car went to the right slightly,
when I reapplied the throttle the car pulled to the left...enough to almost put me in the other lane.
I'm taking the car to the shop tomorrow but I'd like some input from you guys as to what is going on.
Had alignment 6 mos ago...shocks are M030 with H&R springs..
Thanks!
Gunter 12-05-2010 11:01 AM
I'd lift the car securely, rotate each wheel, remove each wheel and check the lining on the brake pads. I know the 993 has pad wear indicators but.................maybe they don't work?
stlrj 12-05-2010 10:30 PM
It might be as simple as low tire pressure on the left rear tire.
tctnd 12-07-2010 05:14 PM
Look for worn rear suspension bushings.
regards,
Phil
RSTarga 12-07-2010 06:26 PM
sounds like your going from rear toe in to rear toe out. Check rear bushings, links etc.
