There is a way to assemble it such that it won't move in the directions it needs to move in. Disassemble, then put the cage around the small race, put the balls in, then put that whole assemble into the large race. If you put it in the correct orientation, the joint will flex and rotate properly. If not, repeat.
Thanks, Tom |
assuming they are put together correctly, my experience is they bind somewhat if dry, if new I suspect they will bind more. if you get one lined up straight and put the assembly in the normal to the ground position you should be able to shake it loose and get things moving... not sure this is much help, after spending so much time cleaning and regreasing the "closed" side I hate the dang things.
A question...why does everyone disassemble their new CV's? I just packed mine and installed, right out of the box... :confused: |
I just finished futzing w/them and managed to get them both reassembled and moving more freely than when I took them out of the box. They are still quite stiff, but at least I can move hem by hand now. Tom |
| All times are GMT -8. The time now is 11:53 PM. |
