-   -   Question about replacement turn signal stalk (http://forums.pelicanparts.com/porsche-911-technical-forum/578754-question-about-replacement-turn-signal-stalk.html)
313green 12-05-2010 04:13 PM
Just got a replacement turn signal from a fellow pelicanite. I only need to replace the stalk. My current stalk is completely worn down to the bone.
Can i simply replace the stalk or will I need to replace the entire component (wiring and all)? Thanks.
Picture of replacement signal...
http://forums.pelicanparts.com/uploa...1291594357.jpg
Jim75911S 12-05-2010 04:48 PM
Replace it as a unit. Something could be damaged in disassembly on either part. Chances are the replacement is in better condition. On my car you just pull the steering wheel and the cover and its all exposed.HTH
Flat6pac 12-05-2010 06:41 PM
I like to cut the old part where the harness goes through the knee pads. I string the new harness in through where I cut the old one and follow all the color wires, replacing the one I remove.
Bruce
wildcat077 12-05-2010 07:14 PM
You're better off replacing the whole unit,wires and all ...
It'a also easier to connect the wires on the headlight switch on the dashboard if you remove the switch itself.Do a search before you start,there is a lot of info on the procedure !
Cheers !
Phil
Hugh R 12-05-2010 07:57 PM
IIRC there is a yellow wire loose up there that you can be tempted to connect somewhere, don't do it. I did and it caused the headlights to run through the instrument dimmer switch. That was 7 or so years ago, so forgive the vague unsubstantiated thought.
