-   -   spark plug tool (http://forums.pelicanparts.com/porsche-911-technical-forum/579149-spark-plug-tool.html)
chamilun 12-07-2010 04:47 PM
spark plug tool
can someone point me to where I can buy the spark plug tool? I've searched forever and can't find where to buy one (ebay has none, someone suggested looking there)
thanks in advance
1982 sc 3.0l
wildcat077 12-07-2010 05:09 PM
You have to keep a keen eye on the classifieds forum ... tool kits as well as seperate items like fan pulley wrenches and spark plug tools come up regularly !
Cheers !
Phil
brads911sc 12-07-2010 06:36 PM
Youll need to pay shipping... but here you go...
Spark Plug Wrench Porsche 911 / 914 / 964, Porsche | Design 911
group911@aol.co 12-07-2010 07:18 PM
I have one if you are on the states.
E-mail me.
SuperOldSchool 12-07-2010 07:24 PM
Forgive my ignorance, what is special about this tool? Flexes for tight spots?
Gogar 12-07-2010 07:36 PM
It's the PERFECT length; or maybe he's trying to complete a tool kit.
I don't have one, so I use a 3/8 drive swivel spark plug socket, and tape it to a 3" extension, and it works.
chamilun 12-07-2010 08:05 PM
I actually want one to use. I tried a homebrew solution but quickly learned having the right tool is always so much easier.
Bob, sent you an email. thanks
haycait911 12-07-2010 08:11 PM
post # 11. the rubber holds the plug nicely.
http://forums.pelicanparts.com/porsche-911-technical-forum/539039-help-newbie-spark-plug-trouble.html
pwd72s 12-07-2010 08:12 PM
This adjustable HAZET worked well for me...loved by VW & 914 guys as well...http://forums.pelicanparts.com/uploa...1291781529.jpg
3/8" drive stubby ratchet plugs right in...the moulded wheel is for finger starting so you don't cross thread.
the center adjustment works best for 911...but can be made shorter or longer, your choice.
mapleslab 12-07-2010 08:23 PM
My solution was a standard Craftsman 13/16 spark plug socket that has a joint connected to it...$10.00...I tied a piece of string through the joint and just pull it out every time. all you need is this and an extension.
John W. 12-07-2010 08:42 PM
The original tool flexes just right and really makes the job easier - I like it but I'm sure others have good solutions just the same.
piggdekk 12-07-2010 11:51 PM
the Hazet tool is just perfect. I also use it at mid position, but when I pull the plugs off I make it shorter so the plugs can come out very easily!
woland 12-07-2010 11:54 PM
To remove and install the sparks from my SC I built this costless tool with an old spark plug wrench and a 14 mm. steel sleeve
http://forums.pelicanparts.com/uploa...1291794275.jpg
http://forums.pelicanparts.com/uploa...1291794309.jpg
http://forums.pelicanparts.com/uploa...1291794331.jpg
When the spark runs freely, I extract it with a rubber tool bought at a motorcycle equipment shop .
http://forums.pelicanparts.com/uploa...1291794534.jpg
The work is very fast and I do not run the risk of dropping the candle in the inside
http://forums.pelicanparts.com/uploa...1291794595.jpg
http://forums.pelicanparts.com/uploa...1291794563.jpg
pwd72s 12-08-2010 12:52 AM
Paolo...ingenious! :D Necessity was the mother of invention?
brads911sc 12-08-2010 08:18 AM
Or you could just stop being cheap and buy the proper tool. Its one you will use over and over again...
boyt911sc 12-08-2010 05:38 PM
Some of my favorite tools.......
While I usually enjoy making some special tools for my needs, there are a couple of tools worth the money I spent. These are the valve adjustment and spark plug tools in my tool box.
http://forums.pelicanparts.com/uploa...1291857889.jpg
A 13/16" spark plug tool with flex joint and a 3" extension with locking feature do a good job for 911 engines. There is more satisfaction for some people when you make or build your own tools than just buying them over the counter.
Tony
MBAtarga 12-08-2010 07:21 PM
boyt911sc - please provide the mfr part no for the valve adjustment tool
boyt911sc 12-09-2010 06:10 PM
Tool information.........
Mark,
The valve adjustment tool has the following markings on it:
Blue-Point
YA8890
13 mm
It was given to me by my son. Which was purchased from Snap-On. HTH.
Tony
arbita1 12-09-2010 06:40 PM
Just keep an eye out on this forum and ebay. It's funny when you are looking for something it's usually hard to find. So start thinking about something else you want to buy and you'll probably find three guys selling a spark plug tool.
BTW...the first time I changed spark plugs I didn't have it and taped extensions together. Not terrible, but after you have the tool, you realize how much easier it is.
Peter Zimmermann 12-09-2010 06:56 PM
For professional results...this socket (SnapOn w/internal magnet) has, with my hands and a combination of (1) 3" extension, and (1) 1" extension, replaced thousands of 911 spark plugs. The exterior of the socket must be machined slightly to help with cylinder #1.
http://forums.pelicanparts.com/uploa...1291949586.jpg
http://forums.pelicanparts.com/uploa...1291949615.jpg
