-   -   How to measure caliper piston sizes? (http://forums.pelicanparts.com/porsche-911-technical-forum/57921-how-measure-caliper-piston-sizes.html)
cstreit 01-25-2002 01:36 PM
I'm trying to find out what calipers I have here, they were supposedly from a 993 C4 rear. The pistons however seem to measure about 31/32 and 36/37 mm across.
From previous posts the 993 C4 rear was supposed to have 2x30 and 2x28 pistons... These are definitely not that, unless I am way off measurements..
More likely they are the 993TT rear calipers which used the 2x30 and 2x36 pistons?
How do I measure the pistons to be sure?
Bill Verburg 01-25-2002 02:22 PM
Here is a pic of a typical piston, you measure the diameter at the widest part;
http://www.prospeedmktggrp.com/Brake...new_piston.jpg
Here is a closeup of the new style seal and piston installed in a caliper;
http://www.prospeedmktggrp.com/Brake...on_example.jpg
In the rear the 993 tt uses 28/28 pistons the 993RS which is very rare here in North America uses 30/36, all other 993 C2/4 use 30/28 all other 964 C2/4/RSA use 30/28, all 964 T/TL use 30/34, all 964 RS use 30/34
