arbita1's Avatar
It's a very complete list. I like that you indicate things by mileage AND years as different things require replacement at different times...not just mileage.
Here's my list if anyone's interested:
Item Frequency
Change Oil & Oil Filter- Once/Year
Check Manual Transmission Oil Level- Once/Year
Body Seals/Throttle Cable, Lubricating- Once/Year
Brake System Check- Once/Year
Front/Rear Suspension Check - Once/Year
Replace Spark Plugs- Once/2 Years
Replace Brake Fluid- Once/2 Years
Replace Air Filter - Once/2 Years
Check & Adjust Valve Clearance- 15,000 Miles
Check Clutch Cable Play - 15,000 Miles
Replace V-Belt - 30,000 Miles
Replace Transmission Fluid- 30,000 Miles
Replace Fuel Filter - 60,000 Miles
Matt.
83 911SC
85.5 944 NA - Sold
Old 06-06-2011, 10:21 AM
Resurrecting this thread. Does anyone have this doc available?
1985 380SL
Old 01-03-2018, 11:09 AM
steely's Avatar
Seems to me I saw a really large one on here some time ago - I will search for it and re-post or Edit this.
I didn't see Greg's ss, it's probably more up-to-date.
edit: here is the thread I mentioned, and is not meant to replace the spreadsheet. Long term & Commonly Neglected Maintenance
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-03-2018, 12:59 PM
Mo money = mo parts
The spreadsheet is saved on Google Docs, and Google must have changed their link. I am not sure why I could not edit my original post to update the URL, but am reposting the the updated link.
This is not a definitive list. It was simply my compilation of thoughts and opinions people were sharing regarding maintenance intervals. If there was more than one opinion, I used the more conservative (frequent) interval. Please consider this a starting point. You should be able to download the spreadsheet as a .xlsx file and make any adjustments you choose.
Hope it's beneficial to you.
Porsche 911 Maintenance
Greg
86 Coupe (stock - pretty much like Butzi designed it)
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 01-04-2018, 05:35 AM
Very helpful! Thanks!!
1985 380SL
Old 01-04-2018, 09:55 AM
Originally Posted by yelcab1 View Post
Replace spark plugs at 10K miles? Not likely. These expensive plugs last 50,000 miles.
Drain and clean fuel tank? Never.
Replace front control arm busing? Only when they squeak.
Good list, but overdone for a maintenance program.
My list is:
oil once a year
oil filter once a year
valve adjustment at 15K
Gear oil at 30K or 2 years
brake fluid every 2 years
and repair everything else as they come up
Good list. That's about what I do - or should do.
1989 3.2 coupe, DIY top end at 77k, now 112k
Old 01-04-2018, 06:11 PM
